3.6L is this and export model truck not for USA market?
the 3.6L is only listed for 1500 not 2500 up, why>?
5.7L 2500 there are 5.7,gas and LNG AND 6.7L DIESEL.
NOT THE 3.6L
FOR 1500 pentastar???
wrong engine or wrong model told, IDK.
parts counters and used car sale zero hits 3.6L 2500
zero.
ONE MORE HUNT POSTED AN NOT ONE CLUE AS TO A REAL PROBLEM ,GOAL OR PROJECT. AS IN WHAT'S UP DOC?
KNOWING THE PROBLEM CUTS THE WORK TO FIND IT WAY MORE EASY. FOR THE FREE HELPER.labor.
SCAN ERRORS NOT TOLD RAN FANS GONE CRAZY
DASH GAUGE WENT WILD,
ECT? PID SCANS TOO HIGH TEMP>
WHAT:"?
IF YOU DID NOT UNSCREW ANY SENSOR HOW WOULD YOU EVEN KNOW IT IS COOLANT? ( NO STORY TOLD AT ALL)
THE DASH METER, CALLED COOLANT USES THE EFI PCM ECT SENSOR, AS DOES FAN, AS DOES WELL ALL. HERE.
THIS IS NOT LIKE 1989 BACK WITH 4 SENSORS THE
1 FOR ECT,AND EFI, & 1 FOR AC CUT OUT OVERHEAT AND 1 FOR GAUGE? AND ONE FOR FANS? SORRY no !
THOSE DAYS ARE LONG GONE THEY GOT SMARTER LONG AGO
AND JUST ONE
ECT SENSOR DOES IT ALL AND SOFTWARE MAGIC. DOES THE JOB.
I WILL NOW READ THE SERVICE MANUAL TO YOU, SO CAN YOU.
ECT 3.6l ONLY ANSWSER
THE 3.6l HAS 3 WAY COOLANT VALVE TOO. (ODDLY )
THERE IS COOLANT LEVEL SENSOR TOO
the ECT , means engine coolant temperture sensor,.
is near the thermostat housing. on most cars, not reverse flow rad.
THE 3.6 LITER HAS COOLANT PUMP CONTROLLER (ELECT)
THE SENSOR ECT HAS ONLY 2 WIRES. THERE IS NO OTHER ECTS ON THE CAR. JUST THIS.
AND IS LOCATED HERE
THE RAM DEALER SHOWS, ON THE WATER PUMP NOT A FENDER EVER. id #3 ECT
IF SCANS SHOW IT READS WRONG MOST TIMES AIR IS STUCK THERE, AS IN NOT PROPERLY BURPING THE AIR OUT OF THE LOOP.
PHOTOS 1:
