Question about Mitsubishi VS-45607 45" Rear Projection Television
Picture at times when I start the TV or it's been on for a while I get verticle lines with multiple of the same pics racing across the top of the screen and it makes the picture run side-ways. But only at the top 1/3. Please help me on this.
  • Anonymous Dec 30, 2008
    i have the same problem with mine.
  • 934 Answers
Caps in the vertical circuit are causing this and taking it to a reputable shop won't be all that expensive... The tech will ESR (equivilent series resistance) test the caps and replace those with a high ESR or open which should solve the problem..
Bill
Posted on Dec 19, 2007
I turn on my tv when i came from school and my tv has a black thick line across the top of the screen, how do I fix it?
The virticle hold is beginning to fail on your TV. This is caused by a capacitor which over time has gotten hot and is loosing its value in capacitance. It is part of a circuit which drives the verticle hold circuit, so it regulates how tall the picture is. It will eventually shrink into a single line in the center of your screen if it is not replaced.
The bad news is that if you do not feel secure in soldering a component on your TV's board, you will need to pay to have it done.. It might be time to get a new TV in other words. The point is that if that cap is failing, the others are not far behind, because the inside of the old TVs gets kind of hot and drys out the capacitors as they age that way...
Jan 08, 2015 | Televison & Video
Verticle lines across my screen with no picture.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Samsung Plasma HP4252 type SR42P5 verticle blue lines across entire screen
First off there isn't a timing board in a plasma TV. I would guess you have a bad y-sus board.
Feb 20, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
Verticle lines across top of screen
This is a problem with the vertical circuit and because it "repairs" itself, sounds like either a poor solder connection or a failing capacitor. This is a fairly common problem that is easily resolved. If you have repair experience, you can fix this yourself. Please verify the model number and whether or not you plan on attempting the repair and I'll supply additional details.
Thanks,
Dan
Jun 11, 2010 | Daewoo DTQ-25S2FC 25" TV
I have picture at the top and verticle lines at
Your panel needs replaced. Half a picture, top to bottom, provides a quick diagnostic. You panel has a Timing Control (T-Con) board failure. Watch out for part cost, it may be cheaper to replace the TV rather than repair it. I hope this helps.
Mar 16, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
White lines running across screen from right to left
when there is a line from right to left it means a verticle amplifier is faulty, remedy
change a verticle amplifier IC
dont forget to check some capacitors (electrolitic for change of values)
this will solve your problem.
Apr 07, 2009 | JVC AV-36D303 36" TV
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
Trouble with pic
Do you have any picture? If so do you lack part of it or the lines go thru a solid picture undisturbed?
Sep 13, 2007 | Sony KV-27S35 27" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
