Question about Nikon COOLPIX 5100 Digital Camera
"OUT OF MEMORY" Error Message
My wife put a 4GB card in her 5700 which has caused a problem. Later we found out that the biggest card for which it is designed is a 1GB card. Following this, no matter what card is inserted there is an error message that says, "OUT OF MEMORY". We have tried 128MB cards up to 1GB cards and still get the error message. Can anyone help?
  • bitstock May 11, 2009
    I have used cards formatted in an external Sandisk external reader hooked to my computer. I have also used a low MB card formatted in the camera. I still get the "OUT OF MEMORY" message when I turn on the camera. I have tried both Lexar and SanDisk cards of various sizes under 1GB and get the same message. I do not understand fully your statement, "the camera default memory has changed to the camera". I have a manual and will see if I can check the settings. I assume you mean the settings for the default memory which I think is FAT16. Any help is greatly appreciated.
  • bitstock May 12, 2009
    I am pleased to state that I solved the problem. Here's what I did. I had access to three other Nikon 5700 cameras. I formatted cards of various capacities under 1MB in each of the three cameras. I then put one of the cards in the camera with the problem. It came on without the error message, "OUT OF MEMORY". I cheered. The only downside is that it reset my profile but that is easy to adjust to my original settings. It appeared that a card formatted in another 5700 reset the camera to the factory default settings. Problem solved!!
  • 407 Answers
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
Posted on May 11, 2009
I just put a new 4GB SD card into my Pentax Optio S4i camera. When I power it up I get the message "memory card error" Tried another card and got the same error message. Any...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 02, 2011 | Pentax Optio S4i Digital Camera
Canon PowerShot SD400 No memory card message, but there is a memory card installed. Tried multiple memory cards and got the same message. Made sure the memory card was locked.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you're using 4GB or larger SDHC cards, they won't work with the SD400 as that camera was made before SDHC came out. Consider 2GB or less standard SD cards only. They're very inexpensive these days on Amazon..
Dec 27, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera wont read memory card error message say: memory card error, please check the card. I dont think its the card becaouse other devices can read it
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 17, 2010 | Panasonic DMC-TZ5 Digital Camera
I put a new 4gb sandisk hc memory card into my jvc gr d270u video cam and i get card error message with or without the card unlocked.i can not go to the format menu with the card in place.
Hardware of this camcorder supports up to 2GB memory card so 4GB is more than its capacity and causing error.
Try 1GB or 2GB memory card in camcorder.
Thanks.
Jul 13, 2010 | JVC GR-D720 Mini DV Digital Camcorder
I put in a Compact Flash Card and format with camera and I get a message that it tells me out of memory
I HAD THE SAME PROBLEM. FOUND OUT THAT THE CAMERA WILL NOT WORK WITH A 4GB COMPACTFLASH CARD. APPARENTLY IT CANNOT RECOGNIZE THAT MUCH MEMORY, SO IT SAYS IT HAS NONE. I PUT A 1GB CARD IN IT AND IT READS IT FINE. THESE CAMERAS WERE INTENDED FOR USE WITH A 1GB OR LOWER CARD. (HARD TO FIND IN STORES, BUT LOT'S ONLINE.) THE INSTRUCTION MANUAL SPECS 512MB OR 1GB CARDS.
Jun 24, 2010 | Nikon Coolpix 5700 Digital Camera
I put in a new card and I'm getting a message that says memory card error. It's snot locked and it's in correctly
There are several possible causes for "memory card locked" or "memory card error". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out (such as the A520). Others include problems with the switch on the side of the card, and the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 04, 2010 | Canon PowerShot A520 Digital Camera
Put 4GB card in - OUT OF MEMORY appears.
I have nikon coolpix L5, i just brought a 4gb memory card that's supposed to be compatible, but when i go to take a picture it say You cannot use this card?
Jul 11, 2009 | Nikon Coolpix 5700 Digital Camera
Pentax K200D Digital SLR - Error Message "f - - "
This can also happen when the lens have an aperture adjustment ring, and it is not set to the "Auto" setting ("A", on my Sigma)/
Dec 25, 2008 | Pentax K200D Digital Camera with 18-55mm...
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Nikon COOLPIX 5100 Digital Camera Logo
443 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
