Question about Sharp AR-5316 Advanced Digital Imager Copier
H3 code in sharp ar5316
I am continiously getting h3 code in my photocoppier sharp ar5316 kindly help me out
    Habit-Forming:
  • 41 Answers
Heat roller abnormally high temperature
press:
# --> interrupt --> clear --> interrupt
14 --> start --> 1 --> start
Posted on Mar 12, 2013
    Problem Solver:
  • 14 Answers
It sound like you have a thermistor that either has a buildup on it or it is not contacting the fuser roller. I would remove the fuser, disassy and clean every component. Reinstall and usually the problems go away. Let me know if you need more assistance.
Posted on May 12, 2009
My sharp ar5316 wont work it has the code H@ showing how can i fix it
what h4,h3,h2,all of this is for fuser unit ,press # press interrupt press C press interrupt then put 14 then start ,the machine will off and on again
Oct 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
Free xp driver for sharp ar5316 please!
Drivers for Sharp AR-5316 are available at Sharp Official Support site Click here and make selection as under: -
Select AR5316 > Windows XP
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 19, 2010 | Office Equipment & Supplies
I can not set up my system with windows seven 7 please send softwere for my syetems . my sestem is sharp AR5316E
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
Photocopiers > AR5316E > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
CreativeTECH
Sep 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
How can i scan an image to computer with sharp ar5316e
The Sharp product description page lists this device as a printer/copier. It's scan function will only produce local copies on itself and it will not scan to another device or computer.
May 27, 2009 | Sharp Computers & Internet
Getting code H 3
The printer repair guy just left. I'm paraphrasing what he told me:
The Sharp MX4501N was displaying the error: H3-04. This does mean that the printer was reading an above average temperature for the fuser, for some reason.
He said that in his experience, 90% of the time, this is due to power surges/spikes and not an actual incident of the fuser over heating. A good surge protector isn't normally enough and he recommended that we look around for a cheap UPS to condition the power.
Other things that can cause a higher than average reading of the fuser can be caused by paper jams, where a piece or pieces of the paper are lodges inside, insulating the fuser and restricting air flow to the internal compnents. Printing 15-25 blank sheets through the copier can usually dislodge these. If not, call for assistance.
In order to clear the error code (H3-04) from possible powewr surges/pikes, I was given the following code: #P, *, C, 1,4 PRINT
This will remove most of the codes restricting printing to the copier, however, should the code reappear, contact customer service and arrange for a visit from the local repair person.
I hope this helps anyone else who may run in to the same problemThe error: H3-04. This does mean that the printer was reading an above average temperature for the fuser, for some reason.
90% of the time, this is due to Power surges/spikes and not an actual incident of the fuser over heating. A good surge protector isn't normally enough and recommended that we look around for a cheap UPS to condition the power.
In order to clear the error code (H3-04) from possible power surges/pikes, I was given the following code: #P, *, C, 1,4 PRINT
May 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Oct 20, 2008 | Sharp AL 1631 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
179 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
