Question about Kenmore 22422 Top Load Washer
Water not drain all the time
I have a Kenmore top load washing machine, it is about 13 yrs. old.
It is not draing all the water all the time. It seems to do this every couple of loads. What would you suggest.
Thanks
Dee
dstouffer@bcpscc.org
  • 43 Answers
First check for any blockage in the drain hose.Remove it and make sure nothing is obstructing it. Is the hose kinked? If not your propellers on pump are worn and you will need to replace pump.
Posted on May 12, 2009
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Jun 03, 2010 | Kenmore 15864/15862 Top Load Washer
WASHER WILL NOT AGITATE OR SPIN WILL FILL AND DRAIN KENMORE 800 TOP LOADER APROX 13 YRS OLD
sounds like your motor coupler bad if its making a ratchety kind of noise
Jan 15, 2010 | Kenmore 23822 Top Load Washer
Will not fill with water
Hi, First thing to check is the drain. Make sure your drain hose is higher then the water level and make sure, if you have it draing into a sump that the end of the hose is not laying in the water. I hope this helps. Please let me know,
Thanks
Vic
May 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Washing machine top loading
no codes are on, all lights are continuously on and water is draining out, wash cycle is not strting
Feb 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22422 Top Load Washer Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
