Question about Samsung HP-S4253 Television
How to Locate, Replace Capacitors on a Samsung HP-S4253 Plasma
My TV has no audio or video!! I have read, but can't find again, a problem with the Capacitors on a HP-S4253 Plasma TV. I removed the back and viewed the Power Supply Board. I don't find anything labeled 3300uf-10v. Can anyone help me located them so I can replace them with 3300uf-16v?
Please email at joan@goldbear.com.
Thanks, Joan
  • 18 Answers
SOURCE: Samsung Plasma SPN4235 No Picture/But Sound
POWER SUPPLY IS WORKING IF YOU HAVE SOUND..WHEN Y-SUS GOES BAD..IF PUTS HEAVY LOAD ON POWER SUPPLY...WHEN YOU TRY TO POWER UP UNIT..IT WILL GO TO IMMEADIATE SHUTDOWN...THIS IS NOT THE CASE HERE..YOU SAID YOU HAVE SOUND...SOUNDS LIKE A BAD Z-SUS BOARD PROBLEM TO ME..CALL ANDREWS ELECTRONICS IN CALIFORNIA FOR PART # AND PRICE..JUST GIVE MODEL #...JOE ACE
Posted on Jun 12, 2008
  • 2336 Answers
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to jah2mil@hotmail.com
Posted on Jan 05, 2009
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
techman007
  • 1112 Answers
SOURCE: I have a 46" Samsung LNT4661FX / XAA LCD TV. My
Hi:
The 6v difference does not make a difference to the unit, besides this is what is recommended to replace them with 1000uf 16v. The result of the power supply failing may of damaged the T-Con board assembly, this is the board near the top of the LCD Panel, it is under a metal sheild. Replacing this board will solve your problem.
Posted on Jan 27, 2011
Picture goes out in less than a minute but sound keeps going
Typical problem in some video/audio board. However, if this only occurs on a particular video input ie: dvd or vcr, it may just be your wire connection.
Mar 27, 2014 | Samsung Hp-s4253 42-inch Plasma Hdtv
Samsung plasma tv ps42c7hdx flickering lines
Yes, yes, yes. Change all bulgy, puffy capacitors by exactly the same value and voltage. Look for any excessive voltages in these areas where you find such capacitors. But replace capacitors only one by one. Never remove all of them together, as you are likely to misplace the capacitors, creating more problems. Also look for any loose contacts and dry solders.
Aug 04, 2012 | Samsung PS-42C7HD 42 in. HD-Ready Plasma...
My Samsung HD-S4253 42" plasma TV will not turn
did you ever find a solution? Mine is doing the same as of yesterday
Richard prasadram3@yahoo.com
Sep 11, 2011 | Samsung HP-S4253 Television
Screen replacement for my TV plasma hp 4253
buy a new set it is hard to get replacement screen for plasma tv.
Mar 06, 2011 | Samsung HP-S4253 Television
Error diffusion on Samsung 50" PLASMA TV
Yes the diffusion problem on your tv is due to the pdp panel aging. What you can try is readjusting the VSCAN voltage, there is a test point marked VSCAN using a DVM you can first check the voltage, should be around -- 190 turn the adjustment counter clockwise this should reduce the voltage, watcthing the picture turn control untill the sparkling pixels stop. That should do it. The panel is starting to age this may occur again until you can't adjust it out meaning a bad panel.
Dec 08, 2008 | Samsung HP-S4253 Television
Blue static on screen
I have the same tv with the same blue spots. Called Samsung and they directed me to Samsung Canada. Samsung Canada referred me back to the US and the US wants me to make a copy of my purchase order and send it to them. What a pain!
Oct 10, 2008 | Samsung HP-S4253 Television
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Jun 10, 2008 | Samsung HP-S4253 Television
Televison & Video Logo
364 people viewed this question
Jerry Greenberg
Jerry Greenberg
