Question about Refrigerators
Terrific noise when defrosting cycle starts
Hotpoint ML795727 makes a terrific noise when defrosting cycle starts. Sometimes I can make it stop by slamming the freezer door.
    Scholar:
  • 152 Answers
Check the back of the fridge, sounds like pipes are rubbing underneath, if you feel you are competent then follow the next steps, 1. Turn the fridge off and unplug it. 2. get to the back of the fridge with a good light or torch and inspect the pipe work, 3. make sure nothing is touching itself and be careful not to touch the black oval shape object as it may be hot (normal). if everything looks ok plug the fridge in and see if you can still hear it ,if the noise is anything other than pipe work , depending on the model you have , it could be either a fan bearing of the compressor is on its way out.
Posted on May 11, 2009
Freezer door left slightly ajar on my hotpoint refrigerator
HI LINDA.DEFROST ALL FIRST 24/48 HOURS AND TRY.GOOD LUCK.ALI
Jul 06, 2012 | Hotpoint Refrigerators
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Hotpoint FFA45 Bottom Freezer Refrigerator
I have a hotpoint csx27h side by side refrigerator. the freezer get cold but the fridge part just started to where it wouldnt cool down. any suggestions? maybe the defrost?? the only things i have noticed...
check the operation of your damper door between the freezer and refrige compartments,this door opens and closes to throttle cold air from freezer to refrigerator compartment through the cold control,sometimes they freeze upand can't move,sounds like your door has frozen closed,if so,remove entire damper door unit,clean and deice,replace and see if this rectifies your troubles
Jan 12, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer has a wering sound on and on
This problem can range from a variety of things.Defrost control, defrost element/thermostat, defective fan motors, defective start relays and even more. The refrigerator should cycle into defrost every 8 to 10 hours. The fact that yours is making a noise and then stopping every 5 hours makes me think that you either have a defective fan motor condenser or evaporator or a defective start relay. Now if the freezer shows signs of frosting over this will change the whole solution. Give me more information on where and what sounds are coming from. Clean the condenser coil beneath the fridge. and examine the fan and see if top of compressor is too hot to touch, Let me know, Sea Breeze
Jul 03, 2009 | Hotpoint FFU00 Side by Side Refrigerator
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
I REPLACED ICE MAKER UNIT BECAUSE REPAIR MAN TOLD ME THAT THE HUMMINING NOISE WAS DUE TO ICE MAKER BEING STUCK IN A CYCLE. AFTER REPLACEMENT THE NOISE IS STILL THERE. WHEN I SHUT THE ICE MAKER OFF NOISE...
theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
Jul 08, 2008 | Hotpoint Refrigerators
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
HOTPOINT FRIDGEFREEZER
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Dec 20, 2007 | Refrigerators
Variable noise in freezer
That could be an idication that the fan motor is starting to fail. The bearings go out and it starts squeaking and vibrating as the fan blade becomes out of balance. If that fan stops working the fresh food section won't get cold air blown into it and will warm up rapidly.
Feb 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
