Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Frigidaire Upright Freezer Model # LFFU1153DW2 not working
Frigidaire Upright Freezer Model # LFFU1153DW2. Unit 4 yrs old. Did not realize the freezer (in garage) was not working. I turned it off completely and restarted. The light comes on, but the compressor will not turn on. I turned the unit, looked around for any loose ends by the compressor. I noticed the defrost timer (around that area) will clicking. So I turned the knob 2 or 3 clicks clockwise, the compressor started. Not sure if it is a defrost timer issue or a overload on my freezer. (my freezer was packed till the door was barely able to shut.). Thoughts ?
By turning the defrost timer.. the unit came on because, it's in defrost mode?
Which part should I replace? Thanks for your help in advance
shaggyrat
  • 1224 Answers
SOURCE: FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
Posted on May 13, 2008
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
  • 1462 Answers
SOURCE: freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Posted on Sep 07, 2008
diths_kri
  • 67 Answers
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
Posted on Jan 07, 2009
hiltonjug
  • 612 Answers
SOURCE: Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Posted on Sep 05, 2009
I have a Frigidaire FFU17F5HWD upright. I noticed
Reset the circuit breaker. It too maybe a GFI circuit.
Oct 11, 2013 | Frigidaire FFU17F5HW
Have upright Frigidaire freezer, about 2 yrs old, that quit running. Local repair guy replaced part with "3 n/1 Start" solid state relay overload capacitor combination. Worked great for 2 weeks then...
Good day,
That's a no-no. Your compressor carries a 5 year warranty from the factory. However, if anything is altered on it the warranty is voided. You've got an issue with this guy.
Jun 04, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
May 29, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
245 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
