Question about Sanyo HT27546 TV
Frozen on a menu screen
My screen says:
Please connect all signals and antennas to jacks and the terminals on the back.
Then press the Channel UP key.
-I dont have any cable or anything liket that. the only thing that is plugged into the tv is my dvd player. how can i get off this screen and be able to change it back to the dvd input signal.  the input button will not work. and i have unplugged the tv for a couple mins. i also hit the channel up button and it just went through the channels and back to the screen above.
Re: frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Posted on Nov 18, 2008
  • 31 Answers
Well you might know what to do by now, but i just found out, you have to un-hook everything dvd cables etc.. from the back of the tv, THEN, press channel up.  After it loads to 100%, the screen should turn black and then say no signal.. then thats your cue to hook your dvd cables, video game etc..  thats what i have to do with my HD 32 inch Sanyo LCD.
Posted on Oct 27, 2007
When i disconnect everything from the back and press the CH. Up button, it does the scan and just takes me to channel 03.
Posted on Sep 04, 2008
Yo i tried what you said stevetrevino and it didnt work
Posted on Aug 03, 2008
0 characters
3 Points
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
Jan 22, 2011 | Sanyo DS31520 31" TV
Blue screen has audio can change channels and hear different audio but no picture
If you can see menu on-screen display, just get into it, surf for blue-back option and turn it OFF first, and see whether there is any grains appears on your screen. If there is no grains, and only a plane raster, your TVs video processor Ic has got damaged, and should need replacement. If there is grains, you just retune it in autotuning option, and allow it to store all the transmitting signals at that time. This process may take two or three minutes to complete, and you should wait till then. Never forget to connect antenna socket to the antenna terminal of your tv.
If you are using set top box, and connected it to the TV through audio-video cable, your TV has no fault, but the set top boxs' video processor has got damaged. OK,
Nov 24, 2010 | Sanyo DS31520 31" TV
I just bought a 19av615db, located in Ireland. how do I set up? Not connecting it to sky or anything,just want to get local channels for now?
If you are in Nothern Ireland you will need a UHF antenna, and Republic Ireland you will need VHF and UHF antenna to recieve off the air signals.
Connect the antenna to the back of the TV. Turn the TV on, select "menu" button on your remote and slect TV from TV/Cable menu press enter, go to main menu and select channel set up menu and select auto channel button and when finished press menu button, check your user manual for details.
Jan 03, 2010 | Toshiba 19A25 19" TV
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
And here is the manual if you need .
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
How to connect tv set to digial tv tuner converter box
There are two ways to connect a converter box.
The simplest is to use the RF antenna cable supplied with the converter. Connect it from the box (the round threaded connector) to the TV's antenna/cable input connector and put the TV on channel 3 or 4 (whichever the converter box is set to). If your set has screw terminals for the antenna connection, you'll need an adapter to switch from the round cable connection to the screws. This may also have been supplied, but you'll probably need to pick one up at Radio Shack or another retailer.
The other way, if your TV has the inputs, is to use the audio/video output jacks on the converter. Again, the cable is usually supplied with the box. This direct connection gives better picture and sound quality than the RF method. The jacks are color coded: red and white for the audio right and left channels, yellow for video. Just connect them to the matching jacks on the TV and select the video input to watch the box. (If your TV is mono and has only a single white audio input jack, you'll need a Y-adapter to join the two audio signals from the box into one. This is also available at Radio Shack. If you don't do this, you'll only get one channel of the sound when watching a stereo channel.)
Please take a moment to rate this solution if you found it satisfactory. Thanks for asking!
Jan 25, 2009 | Quasar SP-2723 27" TV
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
I need help now
Have you tried turning your cable box off, given it 3 minutes then turn it back on. We have Time Warner Cable and their remote has the tv and cable buttons at the top right of it and sometimes that helps. Good luck
Jun 08, 2007 | Sanyo AVM-3659S 36" TV
Sanyo HT27546 TV Logo
580 people viewed this question
Top Sanyo Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Sanyo Standard (CRT) Television Expert? Answer questions, earn points and help others
