Question about Garden
Wont start is there any way of resting the coil.
Kowasaki fc420v
wont start is there any way of resting the coil.
  • 246 Answers
Hello
>>The Following is a Basic Instruction File I Made for Checking the Coil/Ign Coil/Magnetron/Armature on Small Engines. Any Input is Appreciated.
>>**To Check the Ign Coil; Remove the Spark Plug/s.
>>With a Good Plug, Wrap a Wire Around the Threads of the Plug and Attach the Other End of the Wire to the Engine Block. >>Remove the Blower Housing (metal engine cover). The Wire that is Connected to the Coil/Ign Module from the Shut Off Switch needs to be Removed (unplugged) from the Coil/Ign Module.
>>Now Check for Spark at the Plug.
>>If Spark, then the Shut Off Switch or the Wire is Bad.
>>If Still No Spark, then the Coil/Ign Module is Bad. If there are Safety Switches on this Unit and the Coil is Good; you Need to Check the Safety Switches for Being Bad and Check the Oil Guard Switch also.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
I have a cub cadet commercial 42 in cut 14.0 kawasaki FC420V it will start fine idles for 20 sec then dies
sounds fuel related Mike, it is starving for fuel check everything with the fuel system. maybe rebuild the carburetor. kits are cheap.
Oct 02, 2016 | Cub Cadet Garden
How can a kawasaki fc420v electric start be converted over to a pull start?
Basically, it cannot be converted to pull start without a lot of "engineering", but it is easy to bypass the starter switch as long as the starter itself is still OK.
Sep 04, 2014 | Motorcycles
Fc420v
remove the main jet in the carby and clean out as it has gunk in it preventing the fuel to pass up to the venturi
Jun 16, 2013 | Garden
FC420V Kawasaki back fires thru carb on cold start,runs and starts fine after difficult startts
It sounds like your valves may need to be adjusted...
if they are too lose or worn they won't seat properly and when the engine fires it blows back through the intake valve.
pull the cover and see if the rockers are loose... it only takes one to give you a headache.
Mar 29, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a 1992 isuzu rodeo it wont start the engine is turning over but it still wont crank?
To clarify, if it turns over it cranks.
If you know it is not getting spark to the plugs, you will need to have someone check the rest of the ignition system including cap and rotor, module, and pickup coil in the distributor. (V6)
The first thing a mechanic would do is make sure the coil has voltage.
Jul 15, 2012 | 1999 Isuzu Rodeo
Started kawasaki fc420v put in gear started pushed lever to start mower and it died. check spark plug no spark.
You need to try a new plug and see if you get spark with that one. You may have to get in a dark area to see the spark. A blue spark means it's good, a white spark means Coil is not so good, and no spark means it's a bad Coil. If you still have no spark, then you have a bad Ignition Coil (Module).
Good Luck!
Jim
Aug 08, 2011 | Garden
I have an 1989 ford Bronco II. We had the fuel pump replaced as well as the fuel lines. I started a few times but then stopped, wont start again. It turns over but wont fire. Could this be spark plugs or...
Well take a plug lead off any plug and the plug and put plug in lead and rest it on the engine with the thread resting on the metal block and then spin it over if a good blue spark then coil etc is all ok BUT if no spark then the coil could be faulty or condencer OR points need cleaning and regaping to 12thou
when all in good order start and test run .
Let me know how you get on Ron
Oct 15, 2009 | 1989 Ford Bronco
Wont start
First take a time out and recharge the battery (using a battery charger, not another vehicle) A discharged battery can buffer enough amperage that ignition system can't function correctly if using a jump start.
Second, check spark. If lots of fuel has gotten down to plugs, you should remove and dry them off as well.If no spark, check that 12 is reaching coil. If not, you need to determine why.
There are further tests, but start with what i've outlined before going further. If you find nothing, I'll try to help with the rest.
Apr 16, 2009 | 1991 Cadillac Eldorado
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
