Question about Marvin Quartz Radiant Heater
Loud buzzing after heating up
I have a Marvin Quartz Radiant Heater that makes a sudden loud buzzing noise after being turned on for about a minute or two.  When this starts, the heating elements seem to be fine and the fan also seems to function properly, but it's as if an internal buzzer has sensed a tip over or high temperatures etc. and goes off.  I can rotate the temperature dial on the top of the unit to a lower number which stops the heating and fan functions and the buzzing will also stop.  When the dial is turned back to a higher number, and all the functions resume, the buzzing starts again.  Before I opened it up, I wanted to ask about it first.
Thanks,
Timothy
I believe the sudden loud buzzing is caused by the "overheating" or "tipped heater" sensor. Once the heater is turned off and cooled down or placed in an upright position the sensor should reset. But it doesn't.
Note: Do not confuse the "sudden LOUD buzzing" with a more gentle and "normal" buzzing that many quartz electric heaters heaters emit when they are warming up.
Digression: I seem to recall that an older Marvin Brand vertical quartz tube heater had a small "reset" hole on the top surface that could be actuated with a paper-clip or similar object. (perhaps I dreamt that...) anyway - the current Marvin Heater I have does not have that feature and I can't seem to locate the owners manual AND the company "W. B. Marvin" site is shut down, offering no help. "No Longer in Business. Thank you for your patronage." Couldn't they come up with a few thousand dollars to operate the web site for existing customers for a couple years? "Irresponsible" and "rude" are two adjectives that spring to mind.
Solution that worked for me: Unplug it and gently hit it on the sides or top until it stops buzzing when you turn it on. That is what worked for me.
Elaboration: The first time this happened I dismantled the heater and cleaned the dust off the fan / motor assembly and put a drop of oil on the motor shaft. It may have over heated due to the fan motor not operating - it did have moderate usage for a year or two. This procedure enabled the fan to start turning again. Don't dissemble the unit unless you are reasonably handy and sure you can reassemble it properly to ensure the original safety features still function correctly. Also make sure you pay attention to how the wires are routed (away from the fan assembly) After reassembly the unit still had the same loud warning buzz.
If you can get the unit to stop buzzing, operating the unit on only the 750 watt setting may reduce the chance of the "overheating / loud buzzing" problem recurring.
It may be that the fan is too small to keep the unit cool enough or the overheating sensor is "too sensitive" both of which would result in activation of the "overheating sensor" It could be a design flaw or a "tired fan motor / maintenance" problem. Don't leave space heaters of this type unattended - especially with children or pets around.
Good luck and thanks for the forum fixya.
Posted on Jan 04, 2009
  • 625 Answers
The buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Posted on Oct 15, 2007
I have a Marvin Quartz Radiant Heater Model 4940 that will not turn on. You turn the control knob and it does not make any sound or come on. Where can I purchase the on/off switch?
well b4 you replace anything , you may want to try resetting the tilt switch , this is done by tilting machine front to back , quickly then return it too level surface , then try turning on ?
Oct 15, 2016 | Marvin Heating & Cooling
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Is it safe to plug a 1500 watt Marvin quartz radiant heater, model 4940 into the same receptacle as a lamp with a 100 watt bulb ? We had both appliances plugged into the wall and started smelling smoke...
You had a low end cheap receptacle more than likely or possibly a loose wire on the receptacle. You should have #12 wire fed from a 20 amp breaker and a 20 amp spec grade receptacle.
I am a licensed electrician with 30 years experience. IBEW LU #479 Beaumont TX.
Nov 19, 2010 | Marvin Quartz Radiant Heater
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
My Quartz heater is making a buzzing noise, what could that be?
The buzzing noise was coming from the back of hte unit on the lower left side. It may have been a "stuck" switch & tapping on the side seemed to fix it.
Nov 25, 2009 | Marvin Quartz Radiant Heater
The heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
Oct 14, 2009 | Marvin Quartz Radiant Heater
Nonheating marvin, model 5000, quartz heater
Yes, I got my Marvin, model 500 quartz heater fixed, thank you. Please discontinue further communication.
Nov 29, 2008 | Marvin Quartz Heater With Built-In...
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Heating & Cooling Logo
612 people viewed this question
Top Marvin Heating & Cooling Experts
Oloyede Monsuru
Tom Chichester
Thomas Woodburn
Thomas Woodburn
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
