Question about Dell Dimension 5100 (D51L1) PC Desktop
Need to find a control circuit for the push button to start the PC
  • Frank Zhang
    Frank Zhang May 11, 2010
    why you ned looking for a power on control circuit? what happened your destop?
    President:
  • 2,992 Answers
There isn't any control circuit, unless you mean on the system board. The power switch is just a simple normally-open pushbutton switch that's wired to a 2-pin plug (or 2 pins in a larger plug) that connects to the system board. When you push the button it signals the system board to turn on the power supply and start up. If you're having the problem that your computer isn't starting, you may have a bad power supply or system board.
Posted on May 13, 2009
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
Buttons on control panel of refrigerator not working
The control panel will need to be replaced, the buttons and the circuit board are all one piece.
May 17, 2012 | Amana Refrigerators
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
My 2001 nissan frontier 4x4 cruise control will not activate even though the cruise light will display. it will not lock into cruise. Where do I start checking for possible problems?
look for any loose or corroded wires and failin vacuum hoses in engine area--u need to get it code scanned even if there r no warning lites
Dec 30, 2009 | 2001 Nissan Frontier Crew Cab
WE HAVE TO PUSH OUR GREEN PRINT BUTTON WAY TO HARD TO GET IT TO WORK ON OUR PC 920
You will need to remove the front control panel assembly (2 screws and 1 ribbon cable) with copier opened like removing a paper misfeed (or replacing toner unit). Next, you will need to separate circuit board from control panel in order to gain access to the switch under the green print button. Sometimes, you can use electrical contact cleaner (tuner cleaner) to spray into the switch itself, pressing the switch numerous times to evaporate the solution from inside contacts of said switch. Now use a multimeter to check for continuity while depressing the switch and releasing. If cleaning the switch fails, either the switch will need to be replaced or the control circuit board will need to be replaced...replacing the switch isn't difficult, if you know how to solder. Reassembly is reverse of disassembly.
Nov 24, 2009 | Canon PC-920 Black and White Copier
I pushed the start button on the dryer it turned on but didnot st
The instant you press the button on the console, the motor should start. When it starts a mechanism in the motor operates a switch mounted on the motor (provided w/new motor). That makes a circuit which replaces the action of your finger holding the button by creating a bypass circuit. This bypass circuit takes the start switch completely out of the circuit and keeps the motor running.
Your motor is not making this bypass circuit and needs to be replaced.
Oct 28, 2009 | Kenmore Dryers
Xbox 360 wireless pc controller reciever not working??
My receiver died two days ago, i opened it up, and the Fuse was damaged, dont know how it could happen, not that much of current going thru that receiver, well the thing is all you have to do is get a solderer, and soldering iron, remove the fuse and solder a little cable so that you have a close circuit, The fuse is on the down side of the PCB (Printed Circuit Board), its named after F1
Jul 03, 2009 | Microsoft Xbox 360 Controller
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dell Dimension 5100 (D51L1) PC Desktop Logo
182 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
