My fridge was not running at all yesterday. I pulled it out from the wall and cleaned all the lint out of the back panel , which was blocking the air flow. I now hear the motor running, in the freezer section. What other troubleshooting can I do myself, before calling service to come out and charge me an arm and a leg?
ok first of all don't panic!!!
Move the fridge out from the wall again and unplug it.
get down low with a good torch and inspect the undercarriage of the fridge, there you will see a black rounded shape object which is the compressor, be careful not to touch it because it will be hot , secondly you should be able to see a coil and a small fan which blows air through the coil to cool down the refrigerant, once you can see these objects inspect the fan and see if it spins , if it does then turn the fridge back on and check to see if it is running when the compressor is running, if it is not then the fan is seized and will require replacement, if you think you are competent to carry out the works be sure to take note of what wire goes where, and make sure it is unplugged completely from power supply :)
Be safe!!!
Was this helpful?
Yes
No
Popular Solutions for GE GSS22JEPCC / GSS22JEPWW /
GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side...
Where is the fan located at on this appliance? I am a single mom and don't want a repair expense...
(More)
Where is the fan located at on this appliance? I am a single mom and don't want a repair expense right now. The refrigerator is not cooling but the freezer is fine. Cleaned everything out under the frig and and there is very little ice on the rear of the freezer wall
i have a general electric side by side model gss22jepaww, it will not dispence water,ice maker...
(More)
i have a general electric side by side model gss22jepaww, it will not dispence water,ice maker dispencer works fine,any ideas?
Hello, I have a GSS22JEPCC. It is 3 years old. The refrigerator is not cooling and freezer is not...
(More)
Hello, I have a GSS22JEPCC. It is 3 years old. The refrigerator is not cooling and freezer is not very cold either. I know that the refrigerator side is not working. I took off the back vent panel, there was dust on the fan which I vacuumed, but there was no ice, nothing was frozen. I touched the copper coils and they were cold. Any suggestions. Giovanni
The red light on my water dispenser went off along with the beeping alert. I got a new water filter...
(More)
The red light on my water dispenser went off along with the beeping alert. I got a new water filter and followed the installation instructions - let the water run for 3 minutes before pressing the reset button. The beeping and the red light continues.
