Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Will gas cap from can corrode in my tank?
Will the the little white gas cap from 2 gal can that fell in my JD 755 tank when pouring gas in corrode in the tank? It won't float to the top where I can see it and fish it out?
  • 246 Answers
Hello
The Cap can Corrode or even be Pulled Over the Outlet of the Tank and Restrict the Gas Flow to the Carburetor.
If the Cap is Metal, then use a Telescoping Magnet (avaliable at your Local Auto Parts Retailer for less then $10.00) to bring it to the Surface and then Needle Nose Plyers to Remve it from the Tank.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
I have 1/2 can of 8 oz oil per 1 gal gas. I need to change it to 2.6 oz oil to 1 gal for a weedeater. How much gas should I add to what I have to get the proper mix of 2.6 oz to 1 gal gas?
you buy a really small measuring cup . or guess at it .1/2 can will be 4 oz half is 2 so it is someplace between the 2 of them .
Oct 16, 2016 | Garden
My 1996 JD 755 diesel loads up and burns black smoke little power
check the air filter ???
check the exhaust ???
possibly bad fuel ???
Oct 25, 2014 | John Deere 650 750 850 655 755 855 955 670...
I added 0.4 oz of oil to 1/2 gallon of gas too much to mixture. How can I dilute the mixture without starting over?
??? Take a gallon gas can, pour the I/2 gallon oil/gas mixture into it and then add the correct amount of undiluted gasoline to the correct mixture. For instance, if you need a .2 oz/I/2 gal ratio then add 1/2 gal gas to what you already have. Remember, it is always better to have a little too much oil than gas.
Jul 30, 2014 | Husqvarna Weed Eater 26 In Deck 190 CC...
Ran out of gas how do i restart car after putting one gal of gas in tank 1998LS 400
take lose the hose running to air filter or take the hose loose from the throttle body and pour you a little gas in to the throttle body put the hose back on and try to start it,it should start
Jan 10, 2012 | 1998 Lexus LS 400
The sprayer nozzle is stopped up, i have tried cleaning it out and it still won't spray.
Round up 1.33 Gal Spray can have a bad pump or a clogged filter or both.
Test pump: pump the handle, does it get harder to pump after 10-15 pumps, when you open the cap does air rush out? If yes, pump is good, if not, wear rubber gloves, remove pump/cap assembly, remove inner tube from cap, the handle\ pump plunger will remair with the cap. if the o ring is dry, wipe it clean, put a little petroleum jelly on the plunger o ring To Lubricate it and prevent o ring wear and helps it seal air tight so the pump will work correctly. reassemble handle\cap make sure the Black inner black plastic hose aligns with the white spray hose .
If your pump passed the pump test, lool inside tank at the chemical fluid clean or does the fluid look like it has lumpy white clumps in the fluid, if so, empty fluid in tank into a clean throw away container look at rinse the tank out with water, strain the clumps out with a paper towl draped over the tank opening inserted about 2 inches into tank opening then when you slowly pour the fluid back in hold both end of the paper towel so it does;nt fall in tank the clumps will remain on top of the paper towel , Then your ready to clean the filter in the cap. Remove the black plactic tube from the pump, remove the white out side hose(squeeze the black connector to unlock the white hose , Then look in the hole the the black tube was inserted into, look for clumps (looks like lint from a clothes dryer, about the size of cotton ball, ) in that hole, to clean the clogged filter,I used low pressure air from an air tank, Blown into the hole where the white discharge hose was mounted. The clog should fall out of the opposite hole where the black tubs mounts. Reassemble and test, Also, the white spray tip turns out to change from spray to stream. Wash Hands good the chemicals can soak into your skin, some people are very allergic to the fluid
Jul 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
6 gal tank puts out only about 2 gal of very hot water. ADoes the same whether on gas or with electric hot rod.
Have you tried it with both (hot rod and Gas ) turned on at same time? Is tank well insulated? (looking from behind tank.)
Does temperature drop off quickly, or gradually? Did it supply hot water better before, or this is first time you really measured it out? Need to keep in mind that as hot goes out the top fitting to hot lines, cold is coming in the bottom fitting and beginning to mix with hot, which obvioulsy will cause hot to gradually become warm as it enters. 2 gallons out hot tap, 2 gals., at bottom of tank, then mixing as it flows in usually equals, about 2 gal or less of warm, then cold again. Get many complaints of only enough for a short shower when they have 6 gal tank. You can try adjusting temperature up a little to see if it helps. Keep an eye on pressure relief valve dripping excessively as well as shut pump off for 20min-30 min, then turn it back on before touching any taps, to see if it cycles at all, indicating a leak in the system. If pump doesn't cycle when turned back on, no leaks.
Jan 27, 2011 | RTO Atwood Water Heater - 6 Gal LP
Filled truck up with fuel and fuel guage stoped working
There is a TSB for this issue ( TSB 08-2-9 ).
The problem is high sulfur content fuel will cause a problem with the fuel level sending unit, and cause it to read incorrectly.
The 2 times I had this happen, I was not at my normal brand fuel ( had it happen with Shell fuel both times ).
I fueled at 1/2 tank with my normal brand, and then after another 1/2 tank fueled again, and the problem went away.
If you want, the TSB lists new revision fuel level senders, that you can drop the fuel tank, and replace your exiting one with to cure the problem.
The correct P/N depends on your truck cab & bed config, and options
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132 WB
8L3Z-9A213-F Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139 WB
8L3Z-9A213-G Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-H Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163 WB
8L3Z-9A213-A Kit - Fuel Sender 2004 through 2008 - Gas-26 Gal Tank - 126/132 WB
8L3Z-9A213-B Kit - Fuel Sender 2004 through 2008 - Gas-30 Gal Tank - 139 WB
8L3Z-9A213-C Kit - Fuel Sender 2004 through 2008 - Gas-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-D Kit - Fuel Sender 2004 through 2008 - Gas-36 Gal Tank - 145/151/163WB
Aug 20, 2010 | 2004 Ford F150
Thank you for answer to gas cap in tank. It was a small white plastic cap that fell in. I tried topping tank to see if it would float to top where I could see it, but I never saw it. It has been over a...
Hello barbinthebar:
If the Cap was Small, then it May Simply Degrade and Turn to a Liquid and be Burn with the Gas.
>>I had a Customer have this Happen a Few Years Ago and by the Time the Shop was Told and Tried to Locate it in the Tank it was Gone.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
49 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
