Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Reset tv after replacemnent bulb sony
Reset sony tv,
  • 3 more comments
  • rick201m May 11, 2008
    I have an older (12-14yrs or so) Sony 46" rear projection tv. The screen has now gone black and the red blinking light is continuously on. Does that mean the projection lamp is burnt and I just need to replace that? The audio is fine.
    Thanks for any help.
  • Anonymous May 17, 2008
    I am having the same problem. I hear the audio fine but the screen is black and there is a red blinking light in the front. What is the problem?
  • aade1516 Oct 21, 2008
    i get a red blinking light and the screen black and i hear audio. is it the bulb.
  • griffhaney Oct 28, 2008
    screen glows green and the red light flashes on the front
  • reggie007 Nov 08, 2008
    sony TV KP-46WT500 screen green on startup then red blinking light in front. TV then shuts down after 30 seconds.
Red light in the front flashes
Posted on Jan 25, 2008
    Genius:
  • 1,694 Answers
Step by step procedure available in service literature...
Or try to get a local tech to help....
Posted on Nov 04, 2007
SOURCE:
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
Why cant i get the color red on the screan
That model is famous for having weak CRTs and or drive board issues. Replacing the RED crt and Red Drive board should solve the issue. You can get the replacemnent red CRT assembly which includes the drive board from www.tvrepairworld.com
Oct 04, 2012 | Sony KP-57WS500 57" Rear Projection...
I replaced the bulb in my Sony TV . when it powers on there is a warning that the bulb is about to expire
With the model number either Google "lamp timer reset" or call Sony; note that the lamp timer reset should be in the owner manual and is done with the Sony remote control.
Apr 16, 2012 | Sony Televison & Video
My tv is on standby and will not turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Dim picture on a sony kp 53s35 53in. projection tv
hello before you buy a bulb have tried the resetting the picture go into the menu on picture setting have half way down it should say reset click it .it should brighten up the screen
regards
sha
Mar 18, 2010 | Sony KP-53S35 53" Rear Projection...
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony rp tv kp-53xbr35 wont turn on
YOu may need to replace the bulb in the unit, check the bulb and if blown, you need to replace and after replacing reset the lamp time hours. Good luck.
Nov 14, 2009 | Sony KP-53XBR45 53" Rear Projection...
Headlight bulb replacemnent
you don't you unscrew the lamp holder and pull the bulb out and pry the bulb from the bulb holder asembly.
Jul 22, 2009 | 2003 Kia Sedona
How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Sep 18, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
608 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
