Question about Vacuums
Vacume. motor wont spin
There is power at the two metel pieces that sit perpindicular to the magnetat the motor . But it wont spin. Is ther an inner fuse that burnt?
    President:
  • 389 Answers
Most likely the carbon brushes are burnt out and need replacing. However - I wish I knew how to put this politely - if you don't know enough about electric motors to have checked for this already, you may not know enough to do the job safely yourself. Electricity can kill - be careful!
If you need guidance, post a comment here - and be sure to state make and model of your machine. Good luck!
Posted on May 14, 2009
Hoover carpet cleaner brushes wont spin
First i would be checking for a mechanical restriction stopping the brushes from spinning like hair or similar wrapped around the brushes and jamming them, if all is clear it could be a belt broken or slipping, a stripped gear or an electrical fault, depends on what type of drive system the brushes on your particular vacuume cleaner uses. Hope this is helpful.
Aug 17, 2017 | Hoover Vacuums
Why Kenmore Central Vacuum wont power on?
The unit is overloading proberbly because the motor is seized or burnt out
Remove motor and bench test
Aug 09, 2014 | Kenmore Vacuums
I have a model 3241, vacum has suction power but roller is not spinning.
I am assuming the motor in the power nozzle is running, right?
Please unplug the machine first and then check if the roller turns freely.
If it does, then likely the little belt either slipped off the motor or it broke.
May 24, 2011 | Miele Vacuums
I snagged a loose throw rug with the Dyson last night. It jammed the brushes which stopped spinning, Once I removed all the entangled fibers the motor won't turn. The vacume still sucks, but the brushes...
Have you checked the belt? You can do so by removing the bottom plate from the power head. Once removed, check the belt. If broken or worn, it needs replaced.
An instruction video for replacing the belt can be found on the below link.
http://www.youtube.com/watch?v=Z1nSYmrLLsE&feature=related
Feb 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The motor is spinning and spinning the beater motor but the beater bar wont spin
Check to see if the drive belt to the beater is broken. Also, remove the beater brush and clean as best you can. Add some WD40 at both ends of the brush where the hard rubber/plastic pieces are that hold it in the unit. Spin the beater by hand to make sure it moves freely.
Oct 04, 2010 | Vacuums
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Brushes don't turn
i once was a vacume salesman and i have handled a lot of differnt kinds of vacumes there are a few things that will make the brushs not spin the belt could be broken is some there is a swith that when you lower the handle will turn on the brushes. or if the vacume is on the barefloor setting in somecases they also wont spin i hope this helps.
Nov 11, 2006 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
