Question about Kenmore 64902 Electric Dryer
Dryer wont heat but runs
Dryer runs but is not heating
  • Kenmore Master
  • 1,252 Answers
If drum turns but does not heat, look for:
1. A safety device at the elements that has tripped or malfunctioned.
2. Time has malfunctioned and needs replaced.
3. Exhaust system is clogged or restricted causing a safety to activate and stop the heating process
4. Element has burnt out. Wire to the element has come loose or burnt off due to loose connection.
5. Improper voltage to unit. Reset breaker and verify that proper voltage is to the unit. (Usually somewhere between 208 to 240 volts depending on where you are at an the manufacturer of the unit.)
Check these things out. Please keep in mind that a new unit may be cheaper than a repair. I encourage you to do your homework on this. I have gotten dependable units as low as $200 for places like Lowes. They also come with warrenties!
Let me know how you come out and Good luck to you. I truly hope this helps.
Posted on May 11, 2009
    President:
  • 1,136 Answers
Hi, Unplug the dryer and remove the rear panel (on most models). Then take a continuity test on the element as well as the thermostats and the thero fuse. If any of these parts have no continuity, they are bad and will need replaced.
I hope this is helpful. If I can help further, please let me know.
Thanks
Vic
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
Dryer wont heat
could be the heating element cant check with meter have to open her up and see if one of the heat coils is bad a new one will cost around 80$
Jan 14, 2010 | Kenmore 73952 Gas Dryer
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
My dryer wont heat up...It runs but will not get hot.
check all the thermal breaker at the back. If they are good then the dryer heating element may have opened.
Jul 01, 2009 | Kenmore Dryers
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 | Dryers
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Kenmore 64902 Electric Dryer Logo
167 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
