Question about Garden
ROPE ON MOWER WON'T PULL OUT
I WAS MOWING USING TROY BILT 430 SERIES LAWN MOWER. IT SHUT OFF DUE TO HIGH GRASS. I TRIED TO RESTART IT AND THE ROPE WOULDN'T COME OUT ENOUGH TO PULL. I CAN'T GET THE TOP PART OVER ROPE PLATE OFF TO CHECK IT. CAN YOU SHOW ME HOW OR WHAT KIND OF TOO TO USE? THANKS! I have at least a similar problem. When the mower dies, the restart pull feels like I'm trying to pull a stubborn mule up a hill. I have no idea why, but I found that if I push the stopped mower a few feet the pull start operates easily again. Anyone know why?
  • abehs May 12, 2009
    I can not pull rope at all. Any way to release it?
  • hankp_2000 May 13, 2009
    After i take off the the plastic hood...It looks like the housing for the pull-start is riveted on. Now what can i do?
    Problem Solver:
  • 6 Answers
Look under neath and see if anything is stuck in the blade. You probly have a cover for the top part; see if you can pop off a plastic top if you have one.
Posted on May 12, 2009
3 Suggested Answers
  • 420 Answers
SOURCE: ROPE ON MOWER WON'T PULL OUT
I agree, it sounds like the mower is fouled with foliage at the blade. Pull off the spark plug wire and tilt the mower on its side opposite of the carburetor, check the underside of the mower for impacted grass clippings.
Posted on May 14, 2009
SOURCE: Rope on mower won't pull.
due to the ethanol and additives in todays fuel it can also be your carborator. one of the intakes may be clogged and all gummed up.
Posted on Jun 11, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
I have a 2006 Cub Cadet Push mower with a 5.5 160cc Honda Engine. I have never had any problems till last week. The engine started racing while mowing. I stoped the engine and checked the oil and air...
Replace engine, only 1 yr. warrenty. Engine about $119 at Harbor Freight. Easy to change out. all Harbor Freight engines are Hondas. Bolt pattern same. 160cc or 190cc will work. Remove blade, remove mounting screws, replace engine. Carb may be the same for throttle connections. Reinstall blade. 10 pulls required to start engine 1st time. 1 pull after that. Pull 1/2 way 4 times 1st to prime even if you use the primer bulb. Ensure oil is full, 30w oil. Excellent engines good for 7-8 yrs with proper maintenance. Observe cable connections before old engine removal. Take pics.
Sep 14, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Starter rope on walk behind mower is hard to pull so mower won't start
Pull the spark plug out and give it a pull. It should pull VERY easily. You could have a vapor lock inside the cylinder and this will clear it. If it still doesn't pull easily with the plug removed then you've probably either bent the crank shaft or seized the engine, due to a lack of oil in it. Hope this helps. Best of luck.
James
Sep 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Apr 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy Bilt push mower and everytime I try and pull the string to start the mower it gets caught and won't let me start. It's like it's tangled up inside, but when I mess with it it will give a...
You need to remove the rope hand recoil - which will unbolt, and rewind the rope. The coil spring may be broken or have become unlatched from its mounting point. There should only be about four parts, the housing, the rope, the reel that the rope goes(with the rachet in the center) in and the spring that brings the rope back. If there is nothing broken, you can reassemble it. Often times the mechanism is gummed up and needs cleaned, cause of grass, dirt getting into the mechanism. Also ropes need changed, so if it is old do that or get it done for you. This is not a high cost item for a saw shop to fix if you can't do it yourself. Hope this helps you, Rick
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower cable won't pull to start engine. troy bilt 210 self propelled mower.
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Apr 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
346 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
