Question about Compaq Presario 2199us PC Notebook
Need to move HD from Primary to Secondary IDE Controller
Thanks for the response to first posting - but BIOS (which I just updated) does not offer the option to move the HD from the primary to the secondary IDE controller on my Presario 2199US running XP SP3.
Is there a better version of BIOS out there, or is there some other way to change it in SW ? My primary controller is stuck in PIO mode and resetting it in Manage Devices and the registry does not help. The secondary is in DMA so I want to move the brand new HD (I replaced my original) to it the Secondary IDE COntroller to get the better speed.
  • Anonymous May 11, 2009
    Thanks - I understand about that, but it s a laptop and I'd rather not take it apart if I can avoid it. Also unlike a tower, I cannot be sure there is a HW method to switch it.
    its so easy man.....dont have to upgrade the Bios...open the tower CPU..check the HDD data cable ...find the socket on the mb whr it is connected to,,u will find a similar socket next to it....unplug from the 1st one and plug into the other one and its done
  • bargoot May 13, 2009
    Its a laptop
  • 50 Answers
Its so easy man.....dont have to upgrade the Bios...open the tower CPU..check the HDD data cable ...find the socket on the mb whr it is connected to,,u will find a similar socket next to it....unplug from the 1st one and plug into the other one and its done
Posted on May 11, 2009
IDE Hard Drives cannot be seen by Bios in either
the "controller" is actually located in the unit-so check all cables first -if still not seen then my guess is the unit itself is bad-()try with a known good HD
Sep 12, 2009 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
Presario 2199us How to switch IDE HD from
In BIOS boot order; you just switch them.
or
On the motherboard you switch the wires connected to the motherboard.
May 08, 2009 | Compaq Presario 2199us PC Notebook
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
Thanks for responding
oh sorry your PC dont have any SATA controller...
listen, try to check if the BIOS recognize the HDD...(you will see something written near the PRIMARY IDE like in these pictures:
http://img80.imageshack.us/img80/4849/cdburner11rs0.jpg
http://img54.imageshack.us/img54/7770/mtkflashpb8he.jpg
Jan 08, 2009 | Compaq Evo D500 PC Desktop
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
Cone of HDRW720 Hard Disk
In order to use this software you need motherboard with two IDE ports.
You have to use both primary IDE ports, HD must be single mode...
IDE1 Primary - Your HD
IDE1 Secondary - Don't use it
IDE2 Primary - Your HD
IDE2 Secondary - Don't use it
Because it was so long ago I don't remember exact details, and it takes time to reconfigure PC...
But if need help let me know, and I will get you step by step instructions...
May 26, 2008 | Philips HDRW720 DVD Recorder
945GZT-M: HD listed as third IDE master in bios
If the drive is set as Cable Select you are allowing the motherboard to detect where it is on the ribbon cable. If the drive is shown as Primary slave then the drive is on the wrong connector on the ribbon cable. If it is shown as secondary master than the IDE cables on the board need to be switched (primary to secondary, secondary to primary)
Apr 10, 2008 | ECS 945GZT-M (V1.0) Motherboard
I CANT USE MY SECONDARY IDE
Format system and reinstall oprating system
if problem still continue so update bios
download from www.asus.com
Mar 08, 2008 | ASUS A7S333 Motherboard
Secondary IDE not working
Try to check if there are some capacitor has been damage. Replace the capacitor in each specific specification. You can do it yourself by using soldering iron.
Hope this is helpful to you.
Please vote me if I'm done correct solution.
Oct 30, 2007 | ASUS A8V-VM Motherboard
Compaq Presario 2199us PC Notebook Logo
268 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
