Question about Logitech Cordless USB Freedom 2.4GHz Wireless Joystick - 963283-0403
Light on the Joystick no longer lights up.Joystick works fine otherwisr.Georger!
  • 35 Answers
Hi
Dono how good you are with a screw driver and a cable tester but ok here we go.... you will need to open the joystick and test the wired connection to the LED (bulp) if you tested the cables and you do have a power feed to the LED then you need to replace the LED it self.
Hope this helpes
SlitWrists
Posted on May 18, 2009
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
No lights on joystick
Here is a parts catalog for the M41. http://www.invacare.com/doc_files/06_108.pdf
If it was working fine before you swapped the batteries then you did something to interrupt the current flow. Pages 49/50 show the location of the controller with a picture. Unplug the connections here and make sure they are clean and in good shape. Make sure all other connections are clean and tight.
If you have 24V coming off the batteries into the controller, and 24V going out to the joystick from the controller and still nothing is working, then you will probably need to get ahold of an Invacare service tech to replace the joystick. Before he does that he should swap out the old joystick with a new one to see if that is the issue. Invacare parts are pretty pricey...joystick by itself is over $500.00. If the controller is shot, then you can double that cost. Sometimes, both need to be replaced as they can kill each other.
If the chair is old or has a lot of hard hours on it, you can usually shop around on Craigs List, etc and find a good newer/near new chair for about the same price as a new joystick replacement.
Feb 23, 2015 | Electric Mobility Invacare Pronto M41...
Everything works fine but won't manually turn off, but will time itself off.
There are two possible likely problems here: the joystick "key" or contact on the printed circuit board is bad/worn or the joystick is defective. The "key" is the rubber button pad that you press to turn the PWC on and off. This keypad is carbon embedded rubber that makes contact on the printed circuit board underneath. When these age or get moisture, the contact on the board oxidizes and the rubber becomes de-carbonized resulting in a poor contact when the key is depressed. Cleaning the contact with rubbing alcohol and a light scraping tool works sometimes. Replacing the keypad is a must.
If these don't work then you have a bad circuit board in the joystick. Either replace the joystick or the PCB within it. PCB replacement must be done by a properly trained electronic tech or Curtiss\PG Drives who makes the joystick.
Mar 16, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
I have the tdx sp and the wrench light is flashing 7 times what does this mean?
There is a problem with the remote joystick. Could be a bad connection or bad harness to the remote joystick. If harness is fine then the joystick has issues and needs to be replaced or rebuilt.
Try the 4-wire harness first.
Nov 03, 2013 | Invacare Supply Group Invacare Pronto M91...
My reset buttonand the motor conection where it plugs into the little black box have been bypasted my controller went out i got a new one when i pluged it up it had 4 yellow 3 red 1 green light on it can i...
Why do you want to byass the power module? the lights you mention are ok just need to charge your batteries a little longer to get all the green lights on. If you changed the controller, plug all your cables into the new one and try the chair it should work like its supposed to. I really don't know what specific problem you have. Is the chair not working when you tun on the joystick? are you getting any flashing lights on the joystick? are your freewheel levers in the drive position? Let me know something morwe specific Thanks
Apr 09, 2011 | Health & Beauty
No signal for joystick
If there is no light on the receiver then I'm sorry to say it might be fried!... Try unplugging and leaving it for a while ... I know that seems like a bit of a whacky idea but this often works with some hardware I have come across
Apr 21, 2009 | Computers & Internet
Keypad and joytick problem
Hi
First of all tell me model of cellphone, so that it i can give u proper solution.
bye
sr99mobiles@yahoo.co.in
Nov 26, 2007 | Sony Ericsson K800i Cellular Phone
Logitech Cordless USB Freedom 2.4GHz Wireless Joystick - 963283-0403 Logo
170 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
