Question about Toshiba Satellite A215-S5837 Notebook
Toshiba wireless gets disconnected automatically
Hey.. i have a toshiba a210-19b.. the problem is, wen i connect over a wireless network, it keeps getting disconnected every 2-5 mins or so.. i checked de driver, its a realtek rtl8187b .. what could be the problem? thanks in advance :)
  • 400 Answers
Is the signal strengh strong?
Are you using the correct password if you are usiing one?
Try resetting the router or access point if possible.
Install the latest wireless driver to see if its corrupted:
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
choose your model from the list.
Posted on May 11, 2009
  • 3 Answers
Try the following steps:
1. There could be interference, try contacting your ISP to change the channel of the wireless router.
2. Re-install the drivers and update them from the Toshiba website for the Wireless Card.
3. Try turning off all your firewalls
4. Make sure there are no programs interfering with your network connection.
5. Try entering the following commands into the command prompt
Firstly
netsh winsock reset And then.....
netsh int ip reset log.txt
Hope this helps
Toshiba Satellite M45 WinXP keeps dropping wireless internet connection.
Try to do update from Control Panel - Security Center - Automatic update.
Jan 29, 2014 | Toshiba Satellite M45-S331 Notebook
How to load Integrated Wireless LAN on my toshiba satellite a45-s1202
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop. However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 03, 2013 | Toshiba Satellite A45-S1202 Notebook
I keep tuning on my wireless internet on my dell lattitude d600 and my wireless internet wont come on it doesnt show anything wen i press fn and f2
check the error message when you try to search for your network. If it says it cannot find network in range and wireless zero configuration utility is turned off than click on start go to run and type : services.msc, click ok, on right hand side scroll the window to the bottom and you'll see wireless zero configuration >> double click on it >> change the start up type to automatic and click apply then change service to started and click on ok.
Afterwards check if you see your network name or else
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and than right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network
try it!
Feb 22, 2010 | Dell Latitude D600 Notebook
A devise that will enable my notebook connect to wireless
Hi, You can add the networks through your system prefrences and set the wireless network to automatically connect to your mac book however the recomendation would be to always keep your settings to ask you before connectting to a wireless network, this will keep your notebook secure.
Jan 29, 2010 | Apple MacBook Mac Notebook
Cannot connect
If you're trying to connect wirelessly, you probably need to disconnect from the wireless network in the wireless network manager and reconnect. This will force you to re-type the wireless access key. If you have the correct wireless key, it should connect and give you an IP.
If you're connecting using a network cable, your network connection settings may need to be change so that your computer will get an IP address automatically.
Jan 31, 2009 | Belkin (F5D7230-4) Router (587009)
Will not connect to the internet wired or wireless
Unplug your power from the modem first and after that unplug your power to your router, disconnect all your cat5 cables and wait for at least 20 secs. After 20 secs or so go ahead and plug your power back to your modem and wait until all the flashing green lights are solid and that the link light starts blinking. After that plug in your Routers power (You can also reboot your PC while this is going on) . Wait until all blinking lights becomes steady then re-connect your cat5 from the modem to your routers uplink and last the cat5 cable from the router to your PC. If you'd rather not test the direct connection then go ahead and switch your wireless on.
Your wireless connection properties on your PC under "Internet Protocol TCP/IP" should be set to "Obtain IP address automatically" and that "Obtain DNS server address automatically" should also be set. Your routers should, if not already, be set to automatic DHCP. Make sure that on your Device Manager > Network Adapters that your wireless network adapter is not disabled and that it has the correct driver (yellow exclamation on it indicates it needs correct driver). You should disable your integrated ethernet LAN card if you have enabled your wireless Network Adapter to avoid conflict.
On your Wireless Network Connection properties under "Wireless Network" tab go to "Preferred networks" and highlight your wireless network name (SSID) . After highlighting click on the "Advanced" button and select "Access Point (infrastructure only) networks only"
Jan 23, 2009 | Toshiba Satellite L25-S119 Notebook
SECURITY PROBLEM
first go to router setting page, for access router page the default ip add is 192.168.1.1 try this first, if the router page is not open then check the default Gateway in u r pc and keep the ip add of ur pc ob tend automatically
1. when the page is open then go to wireless potion>wireless security>
2. then select encryption type WEP > 64 bits
3. then type pass phrase>click on "generate network key"
4. routher will generate 4 network key , select first key as wireless security key.
5. save this settings.
now the wireless connectivity automatically disconnected
6. now search the wireless network on u r pc .
7. when u get u r wireless network , then connect to this network
now the wireless network key is ask bye system ,
8. type the network key which generated by router .
and connect 2 u r wireless network
Aug 20, 2008 | Linksys Wireless-G WRT54GL Router
WIRELESS SETUP CONNECTION FOR TOSHIBA TE2100
Go to the control panel. Open wireless connection wizard and configure it by giving the proxy setting of the router. There must be a DNS server to get you connected with the Domain.
First your os xp or vista
if u xp means go to network connection and see that tab, wireless network wizard and click next to open to next to next and click finish. It will appear in network connection windows. But u want to take airtel broad band wireless net key, and u open the tab if u finish ur network wizard tab. And it will open the icon it ask for key, u give it key to continue. It will ready to access the network, so this is the way
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 30, 2008 | Toshiba TE2100 Notebook
Problem with connecting to Orange router
  1. Go to Network Connection
  2. Right Click on the Wireless Network Connection
  3. Click on Properties
  4. On General Tab "uncheck" the items Except;
    • Client for Microsoft Networks
    • File and Printer Sharing
    • QoS Packet Scheduler
    • Internet Protocol (TCP/IP)
      Restart the computer. WZC will start automatically as long as Windows assigned to configure wireless Network
      Good Luck
Dec 26, 2007 | Computers & Internet
Toshiba Satellite A215-S5837 Notebook Logo
299 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
