Question about Frigidaire GLTF2940ES Front Load Washer
Our Frididaire GLTF1240ASO washer will not spin or empty the water. We had this happen once before and a technician came in to fix it. It seemed like something simple that he said this model is known for. He found a guitar pic somewhere and said it was easy to take care of. Unfortunately my wife did not see how to do this. Any pointers?
    President:
  • 1,136 Answers
Hi, He probaly found it in the pump. THere should be two screws holding the front panel on. Then you neeed a screwdrive to pop the top up by releasing the clips located in the crease between the top and the front panel. Once the top is raised, the front panel drops down and then you can move it out of the way. There is an electric style pump on your model sobe sure and UNPLUG the machine before you start working on it.
Remove the hoses from the pump and you might find something plugging it. If there is nothing in it, You can test to see if there is 120V going to the pump. Also check the drain hoses since you are this far.
Hope this helps you. Please let me know if you need more help.
Thanks
Vic
Posted on May 11, 2009
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Frididaire model atfb6000es1
Hi Stacey C - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Extra long rinse cycle for gltf1240aso
Sounds like a bad water valve or the timer is not communicating correctly for each cycle. Contact a professional.
Aug 28, 2012 | Frigidaire ATF6000ES Front Load Washer
FRIGDAIRE WASHER FRONT LOAD MODEL#GLTF1240ASO DOES NOT GO TO HIGH SPIN . A CHECKED DRAIN PUMP REPLACED DOOR SWITCH AND REPLACED SPEED CONTROL CHECKED BELT
Hi, are you sure your pump is operating properly any little thing caught in the impeller will stop these pumps. You also say there water still in the tub it will definitely not spin fast with water in the tub. Remove the pump and inspect the impeller sometimes there are things caught in it and other times the vanes are broken right off.
Apr 21, 2011 | Washing Machines
My GLTF1240ASO has an amplified noise level when spinning? The Drum does have some more than normal back & forth movement as well.
That could either mean that you need new bearings or the spider arms the part that holds the washer tub are broken. It can be very expensive to repair. Get a few estimates before deciding whether to fix or replace.
Jan 07, 2011 | Frigidaire GLTF2940ES Front Load Washer
From time to time the washer does not empty completely, have not been able to narrow it down to any one setting and it onloy happens once in a while. Any suggestions?
Does the washer attempt to spin? It could be that it isn't spinning leaving the clothes soaked and some water in the bottom of the tub. Might want to put it in the service mode and turn the pump on and do a spin test as well. Does this happen on heavy loads?
Mar 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine constantly empties
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Sep 02, 2008 | Washing Machines
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire GLTF2940ES Front Load Washer Logo
449 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
