Question about Car Audio & Video
Poor tuner reception
I have just installed my ALPINE CDM9803RM in to my horsebox and it works fine BUT I can't get very good radio reception - even the everyday channels like radio 1,2,4 etc come and go. I have put a brand new aerial on the lorry but still only get intermittent reception as I drive. Can you help please?
  • 518 Answers
THIS IS NORMALLY DUE TOO BAD EARTHING, MAKE SURE YOU HAVE A GOOD CLEAN EARTH ON BODY
Posted on Jun 13, 2009
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
I just installed a new Sony XT-100HD HD Radio Tuner for my truck. I wanted it so i could pick up more stations and have them all sound clear. After I hooked everything up to see if it worked all I could...
It is always worth checking the aerial in any case of poor reception.
In the case of a standard mast-type aerial it is necessary for the mast to have very good continuity to the centre of the aerial plug, that the outer part of the aerial plug has good continuity to the aerial ground and thus to the vehicle bodywork and the two parts are electrically isolated from each other. A good independent radio ground connection also helps.
In the case of miniature aerials or those within a windscreen, a rear screen or rear quarter glass, the amount of signal available will be small and so an aerial preamplifier will be provided to boost the signal. The preamp might be part of the aerial or a separate unit fitted anywhere convenient. I once found one fixed to the front firewall behind the dashboard.
The preamp needs a good 12 volt supply and a ground as well as good connections to the aerial coaxial leads. The supply is usually obtained from the radio set so it is operative only when the radio is switched on. Sometimes a radio has a dedicated output but mostly the electric (automatic) aerial output must be used. If the preamp isn't working reception will typically be limited to a few powerful stations.
I hope this helps.
Oct 21, 2017 | Sony XT-100HD HD Radio Tuner
How can i test my alpine cva-1005 head unit
You can bench test it by hooking up powers and ground to a battery (12 volt) and use a speaker to one set of speaker wires at a time. Even a 12 volt cordless drill battery will work. Should only take a few minutes. You just won't get reception to radio stations without an antennae.
Feb 18, 2010 | Alpine CVA-1005 Car Video Player
Alpine CDE-9845, no audio from cd's either normal or mp3. Tuner works fine. Where to troubleshoot?
You have the wrong blue wire connected.
Your power antenna wire is hooked to the amp remote wire and vice versa.
Your radio thinks the tuner is off - and is dropping the signal thru the power antenna wire - and turning off your amplifer.
Switch the 2 blue wires in your install - and you'll be all set.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 06, 2010 | Alpine CDM-7874 CD Player
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
Alpine cda 9885 Poor radion reception
Your antenna wire could be loose behind the radio because sometime they will have to use an adapter because of the size another thing could be if you have a sirius/xm radio they will send you an adapter to cut down on the static for free also the adapter on the sirius could be loose or bad good luck
Dec 30, 2008 | Alpine CDA-9885 CD Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Radio reception
If antenna optimization didn't work you'll probably have to move.
Aug 08, 2007 | Bosch PB10-CD Radio/CD Boombox
Car Audio & Video Logo
109 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
