Question about NEC PlasmaSync PX-42VM2A Television
Help T.V. has power but does not come on. Does start up but shuts down. Any suggestions?
  • Anonymous Oct 09, 2008
    yep i got one and its doing the exact same. Its also burn a little blue in color. not to bad except on whites. mostly us it for g-force. hee hee hee....
Same problem here. PX-42VM2A (NEC PlasmaSync 42MP2) Turns on (status light green) then goes to standby mode (status light red) after what sounds like some electrical relays clicking over. Opened it up and no glaringly obvious problem, but i'm no components technician so... Any ideas? Anyone want to buy it for parts or need a specific part? email me: 318noire<at>gmail<dot>com
Posted on Feb 03, 2008
Printer error has occurred - says to cancel printing and shut off, then start again. I wasn't printing and there is nothing to cancel. Shut down numerous times and won't clear & start.
Brand, model, operating system, source of the error message all help in exploring an issue. The printer was shut down several times and the error message did not clear? If the printer is shut off for a significant time allowing discharge of any capacitors (which are similar to batteries) and yet you get an error message when you power back up, it suggests that there is a mechanical problem or inking problem. This would require troubleshooting of the device. You might find help for that on the manufacturer's site. HP, for instance, has a diagnostic program that can be downloaded.
Sep 01, 2017 | PRINTER Office Equipment & Supplies
Dishwasher started to fill with water, and started to cycle the water, but then suddenly shut down and wouldn't start back up. The lights wouldn't go on at all. Not fuse or power problem.
Hello Jeremiah, thank you for your post!
I understand that your Frigidaire dishwasher started a cycle and then shut down. I would suggest performing a reset and you can do that by disconnecting the power cord for at least ten minutes. If you continue to experience issues you may need to replace the control panel or wiring harness. I would recommend having a professional technician out to your home for proper diagnosis and repair. This will help prevent you from any unnecessary part purchases. -Matt
Jan 08, 2016 | Frigidaire FFBD2406NS Built In Dishwashers
Panasonic SA-DM3 shutting down issue
The amplifier is over heating. Probably the emitters, drivers and voltage regulator is bad. I suggest a clean sweep replacing the power pack integrated amp, all emitters, mosfet regulator, and SRC power switch start up control.
Feb 08, 2014 | Panasonic Audio Players & Recorders
Computer wont turn on
Is the fan running in the power supply ?
Unplug all the drive power leads and try it.
If it still shuts down, try another PSU, by just plugging it onto the mother board only. If it still shuts down, I suggest it is a motherboard fault. The motherboard turns on the PSU, when you press the on button, it shorts 2 pins on the motherboard to start the power.
Mar 27, 2013 | Computers & Internet
Laptop will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
May 11, 2012 | Dell Latitude E5500 Laptop
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
My 1998 Olds Bravada just shut down on me while i was driving down the road. My gauges started acting erratically and i just loss all power. I barely had time to get it off the road. I got it started and...
sounds like an electrical problem, check your alternator an battery tru a shop, if the gages go crazy is a sign of the computer trying to shut down componets because the lack of power or voltage
good luck!
Feb 01, 2010 | 1998 Oldsmobile Bravada
Odd shut down delay when power cord is attached
how about running defrag? do this by right clicking on your c:\ drive in my computer and selecting the tools tab. Then you will probably have to run scandisk first but this might help
Dec 28, 2008 | Gateway MX6447 Notebook
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Ibook G3 will not start
If you stilll have the Mac OS installation CD available the when it is starting up press down C and it will start from the Mac OS X installation Set up then you can reinstall OS X and it should work.
Apr 17, 2008 | Computers & Internet
NEC PlasmaSync PX-42VM2A Television Logo
601 people viewed this question
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
