Question about Panasonic KX-T7730 Corded Phone
Ringing everywhere it rings on all extensions including the console. practically it suppose to ring on the console only. but now it rings on the console and the other extensions as well
  • Anonymous May 23, 2009
    mr.carl i have the same problem. I called somebody before and gave instructions thru phone and we removed the ring from other extensions when there is an incoming call. Now I added new phone and Im having the same problem again. All I can do is regret why I didn't wrote it down (instructions) or remember it, because I can't contact that person again.
  • Panasonic Master
  • 2,460 Answers
If it used to work and stopped, I'm guessing the system is no longer in the DAY mode. Each system tends to program differently and the 7730 phone can be plugged into one of about 18 different Panasonic systems.
From the main phone, try dialing 780#. If it beeps and says DAY MODE, it was the right command :-) Now test the lines and see if that fixed it.
If it doesn't work, please go to the phone closet/back room/attic/whatever and grab the model number of the phone SYSTEM and post back.
Carl
Posted on May 11, 2009
Norstar meridian 7208 won't ring.
Does it ring when you move it to a known ringing port? Is it programmed to ring (Terminals & Sets) Appear and Ring? Do you have Automatic Set Relocation turned on so the extension number stays with the phone?
There are a lot of features to check for ringing, including the volume of the set.
Carl
Sep 10, 2011 | NorStar M7208 Corded Phone
On 308 pansonic pbx (kx-t7730), when the incoming call rings all the extension phone and the master (PT or operating console)phone rings.so please help me to make it ring only on the master.thanks
When you take this unit out of the box, you get programming instructions. One of them is the ringing (program 408) for day mode. (409/410 for night and lunch). By default, all phones ring on all lines in all 3 modes. You have to remove the ring to make it go away.
Carl
Sep 29, 2010 | Panasonic KX-T7730 Corded Phone
My phones only light up on my panassonic business phones
If you have a PTPM or the maintenance console, you can program ringing. It's a dealer only product in the U.S. Incoming calls are made to ring ICD (incoming call distribution) groups where the ringing is controlled per extension. In our version, even the manager does not have access to that level of system programming.
Apr 05, 2010 | Panasonic KX-T7633 Corded Phone
Red ring on xbox
Dude, the red ring sucks. Your Xbox is practically ruined. You will have to contact Microsoft, and ask for a new Xbox, they'll be sorry for the inconvenience, and give you 1 year free Xbox Live Membership.
Dec 25, 2009 | Microsoft Xbox Console
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
178 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
