Question about Intel S5000VSA Motherboard
What for is sata raid 5 key used for - Intel S5000VSA Motherboard
    Champion:
  • 381 Answers
Hello..all new or a lot of new hard disk (HDD) and DVD now is SATA cable connector..Like DVD rom player SATA or IDE cable or HDDrive SATA or IDE cable..
Posted on May 11, 2009
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Server raid 5 problems
www.smartcomputing.com/Editorial/article.asp?article..
www.pcguide.com/ref/hdd/perf/raid/.../singleLevel5-c.html -
www.tomshardware.com › ... › Storage Solutions - 8 hours ago
www.tomshardware.com › ... › New System Build
Mar 22, 2010 | IBM SYSTEM X3400 XEON-QC E5410 2.33G...
What is intel(R) matrix storage manager
Yes you need it. document.write("The files below contain the Intel® Matrix Storage Manager.
This driver provides support for high-capacity & fault-tolerant Serial ATA (SATA) RAID 5 arrays and high-performance & fault-tolerant SATA RAID 10 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X and 945 chipset-based platforms. It provides support for high-performance SATA RAID 0 arrays & redundant SATA RAID 1 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925, 915 chipset-based platforms. It also provides AHCI support on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925 and 915 chipset-based platforms, as well as on Mobile Intel® 915/910 chipset-based platforms.
Note: Intel® RAID Technology requires the Intel® ICH9R/ICH9M-E/ICH10R/PCH/PCHM SATA RAID controller hub, Intel® 82801HR I/O controller hub (ICH8R), Intel® 631xESB/632xESB I/O controller hub, Intel® 82801GR/GH I/O controller hub (ICH7R/DH), Intel® 82801FR I/O controller hub (ICH6R).
DISCLAIMER: This software is provided by Intel only for the convenience of its customers. THIS SOFTWARE IS PROVIDED \"AS IS\" WITH NO WARRANTIES WHATSOEVER, INCLUDING ANY WARRANTY OF MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, OR ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. This software is furnished under license and may only be used or copied in accordance with the terms of the license. The software is subject to change without notice. Intel assumes no responsibility or liability for any errors, incompatibility issues, inoperability or inaccuracies that may appear in this software.
See the Installation Instructions page for a list of system requirements and considerations.
Note: Before installing this application or requesting technical support from Intel, it is suggested that you first contact your system manufacturer. They may provide software which is specifically configured for your system.")The Intel® Matrix Storage Manager.
So don't delete it.
Mar 10, 2010 | Computers & Internet
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
SATA Configuration
They are independent sata configurations so you should be able to. Sounds like fun. Good luck.
Dec 24, 2008 | ASUS K8N-DL Motherboard
Software raid/ide
it won't touch them, it should ask you which partition you want to boot from, or which version of windows if your boot.ini files are on the same drive.
Dec 18, 2008 | Computers & Internet
Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the...
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Nov 17, 2008 | Computers & Internet
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Raid none define
Try getting into your BIOS (usually F2 key at first screen, could also be F10 or Del) and check if your hard drive is in RAID or IDE mode. SATA drives can be run in either. Although it is somewhat odd that a simple mem upgrade could case a raid problem.
Sep 13, 2007 | Select Brands Matsonic mATX 800Mhz s775...
Intel S5000VSA Motherboard Logo
242 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
