Question about Kenmore 63942 Dryer
Kenmore Dryer Model 110
Runs but doesn't get hot the dryer is about 14 years old. Could it be the heating element or is it something else?.
  • 6 more comments
  • CHulstine Dec 02, 2007
    Kenmore 80 Series dryer runs but air is not heating and therefore not drying clothing. Dryer is about 9 years old. We cleared out vents and checked connections with not success.
  • granny60 Dec 07, 2007
    Kenmore Ultra Care Dryer Model #110.96583120 was working good and just stopped heating. No lent build up, element not getting hot.
  • Anonymous Jul 31, 2008
    do I have to remove the entire front of dryer to get to the burner assy? It does not have the little rectangle area below the front loader that i have seen before. Also if I have to remove front is there any tricks I should know about?
  • 4Rascal4 Aug 24, 2008
    Thanks for the helpful tips. Unit is in the 13 year old range. Only my wife & I in the household. I have visually checked the elements & they do cycle on & off as you suggested. With the dryer vent hose removed the exhaust seems very strong--the utility room heated quickly. The exhaust run is about 37 feet of solid 4" pipe (only a small flex at dryer outlet to under the floor). About quarterly I use an electrical wire pulling snake with a rag fixed to it to clean the pipe. I turn the dryer on air only & run the snake thru it until no more lint comes outside. The air flow seems rather strong.
    Any other input would be extremely helpful.
    Thank you
  • dncmanning Oct 13, 2008
    Kenmore 80 series running, drum turns, but no heat.
  • cdl94
    cdl94 Aug 22, 2012
    was working then just stoped, there was heat when it stopped, checked push start button, fuse, and door dryer button......outlet is working ....? what could it be.....?
  • Gary Burkholder Jun 29, 2013
    My kenmore HE4 dryer has stopped working. I have checked current (240 at dryer), checked the heating duct sensors the blue wire continuity is okay, the red and black have nothing. what should i try next?
  • Anonymous Mar 14, 2014
    not getting very hot
    New Friend:
Heating element can be found at amazon, click here and take a look: Amazon com kenmore dryer heating element. I hope this was helpful. Cheers
Posted on Dec 21, 2014
  • 5,911 Answers
There are several things that can cause a dryer not to heat properly.  First and foremost, a dryer needs proper air flow in order to work properly.  Routine cleaning of the dryer vent hose should be done periodically.  I recommend once per season (4 times per year), depending on use.  If you haven't cleaned the dryer vent any time recently, start here first.  It could be that you have a simple clog somewhere.
Now...if you've already thought of that, you could actually have more going on INSIDE the dryer.  If your dryer is equipped with a removable front kick panel, remove it by inserting a putty knife along the top seam (about 2 inches in front each side) to release the retaining clips.  The panel should pull open, exposing the heating element and blower housing.  On some models the heat components can be accessed by removing the back of the dryer.
Stand back and watch the heating element with the dryer running.  If it is glowing and intermittently shutting off, this is NORMAL.  You probably have a clog some where INSIDE the dryer.  You will need to unplug the dryer and remove the air blower housing to see if it is clogged with lint.  I have found these blowers so clogged that the fan gets jammed with lint and snaps off at the shaft.  If the fan doesn't spin, there is no air flow and you clothes will not dry.  In this case, the blower fan will have to be replaced.
If the heating element is NOT glowing, and you have verified that the dryer is not clogged, you may have a failure with any of the following components:
HEATING ELEMENT - located inside a heat box.  Unplug dryer and remove connector leads from element.  Check resistance of the heating element.  It should be about 10 ohms.  If it is OPEN, the heating element is bad.
THERMAL CUT-OUT - located on the heater box housing.  Has two leads running to it.  Designed to protect the heating element in an overheat condition.  Check resistance to ensure it is reading something close to a SHORT (0 ohms).  If it is OPEN, it must be replaced.  It is highly recommended to replace the HI-LIMIT THERMOSTAT (which is also located on the heater box, closer to the heating element connectors).  The two components work in conjunction to regulate the heating element temperature.  If the TCO fails it is usually for a reason.  It could be a simple matter of general house cleaning, or it could be a failure of the hi limit thermostat.
I hope you find this information helpful.  Let me know what you find.  Post back with any comments and/or questions.
Posted on Oct 13, 2007
  • Jeff Rockwell
    Jeff Rockwell Oct 16, 2007
    Could you please post back comments as to why the advice given was not helpful?  Instead of leaving arbitrary ratings with no comments, why not let someone attempt to help you further by providing better guidance.  What have you done to fix the problem?  Is the appliance now working?  Do you still need assistance?
  • Jeff Rockwell
    Jeff Rockwell Oct 18, 2007
    Please remove solution.  I work on appliances for a living and took the time to provide a rather detailed diagnosis, followed by possible causes.  I even requested to have any further questions/concerns directed to me, so I could get an absolute solution.  Instead, consumer chooses to leave negative rating with absolutely no feedback.
I found the solution to be very informative and helpful. However, I checked the resistance of the heater element and it is about 10 ohms, and is not open. The TCO resistance is about zero. What about the thermostat? No values were given to check it for, but I did check it's resistance and it was also close to zero. The thermostat sort or "rattles" when I shake it; is that normal?
I pulled the heater element out and looked at it, and can see no visible damage. Also checked the air outlet and hose - no blockage in the hose and the air output at the dryer seems fine.
What else could be causing the dryer to not heat. Have checked at all cycles and temperature settings (low, medium and high)?
Posted on Sep 16, 2008
I've had the same problem and we replaced the high limit thermostat that located on the bottom section of the heating element. $16 repair and it's running like new!!!
Posted on Oct 16, 2008
    Champion:
  • 249 Answers
Is it worth our while when not rated! good or bad????
Posted on Dec 04, 2007
    New Friend:
  • 4 Answers
Ok here goes this is what I found wrong with my Kenmore Dryer 110 64112200 would not heat correctly and we quit using it (wasn't drying the clothes) The Motor Your Dryer uses most likely the same as mine on (110 series)
http://www.repairclinic.com/vwo6/PartDetail/b6p8/Kenmore-Dryer-Drive-Motor/279827/2584?modelNumber=110.64112200&fromRepairHelp=True
all these different forums and sites say You need a motor. Alternating Current Squirrel cage motors are very robust and unless locked up or a open wire coil they work, now that being said the Bottom wire on My motor plug is Red and is connecting L1 and L2 to turn on the Heating Element when the Centrifugal Motor switch is Released because the motor is up to Speed (Turning the Drum) I removed the Motor and opened the black Plug on the Motor the Switchable Contacts inside for the Heater element on the Bottom were fused together. This Condition caused my Heater Element to come on As Soon As I Plugged the Dryer in, caused the timer to tick and it also caused the motor to hum upon pushing the start Button and me having to help the motor start (Spin the Drum By Hand). The Motor would let the Drum stop as soon as the you put any clothes in the drum. The Reason is because since the Red Heater Element Wire Contacts were Welded together in the Motor Plug, when the Centrifugal switch on the motor shaft would release the switch it could not close the contacts for the Motor START Capacitor (the reason that the motors Hums, it can't start). Without the Start Capacitor the AC Motor can not start so it just hums unless you help it. Now also since I Broke the Fused contacts apart again the Motor can start and I Can not stop the Drum Motor Works Fine and the Heater element works Fine. Just some Information the Motor Centrifugal (Fly Weights) Switch is a Double Gang Switch so the motor can start, come up to speed and at the same time Close the Heater Element circuit. Hope this helps Somebody. Myself I can't see spending $82.85 for a motor I don't really need.
Posted on Nov 10, 2014
Msg.14.6228
Posted on Nov 17, 2011
I have a 100 dryer and I replaced the heater element. I have two connection points one is one wire and the other goes through the thermosat to the heater coil. Does it matter which post of the heater coil goes to what wire?
Posted on Jul 24, 2010
Thank you for this, I found it useful.
Posted on Nov 22, 2007
How do i get the front panel of a model #110.86980 off? i need to replace the door lever in the upper right corner to activate the dryer
Posted on Oct 16, 2009
I found this helpful although I did had already checked the heating coil, it wasnt glowing, I figured it was on of the two mentioned but I dont have the ability or tools to check the ohms. But yes it did confirm what my problem may be, thanks
Posted on Nov 29, 2007
5 Suggested Answers
SOURCE:
Maytag317
  • 1136 Answers
SOURCE: kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Posted on Jun 28, 2009
Oceti
  • 51 Answers
SOURCE: Kenmore Dryer Model 110
Using a multi-meter, check to be sure that you have 220 volts at the back of the dryer. If you do, unplug the dryer, take the back off and ohm out the t-stats, thermal cut-outs and element.If you can't pinpoint it to one of these then it will be in the controls or maybe the motor start switch.
ps, The dryer motor will run on 110 volts.
Posted on Dec 13, 2007
TheMobilian
  • 8220 Answers
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 05, 2009
  • 2699 Answers
SOURCE: Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Posted on Dec 13, 2009
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
I have a maytag pye2300ayw dryer it runs but doesnt heat. I replaced the high limiter because it fell apart in my hand when i was taking it apart to check the element. The element has no physical breaks...
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. If the heating element is not broken and there is voltage going to it, it will get hot. Either there is a break that you did not see, or the voltage is not getting to both ends of the heating element. You may have found voltage on one end but the other end may not be properly connected. If you can check the voltage across the element, rhat will tell you something. If you have the full 220 VAC and it's not getting hot, the element is bad. If you have no voltage across it, the element may be good, but the circuit is bad. Be very, very careful making this measurement, there is no second chance! I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. If you have an error code you can probably find the meaning of it there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 26, 2009 | Maytag PYE4558A Electric Dryer
Dryer wil not spin
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 08, 2009 | Dryers
Dryer not putting out warm to hot air. What is the issue?
May 07, 2009 | Dryers
It's almost certainly the heating element, unless you have moved to a home without natural gas from one that did. Then of course, it won't have a source of energy. How can you not know if it's gas or electric?????
Feb 12, 2018 | Kenmore Dryers
Feb 04, 2009 | Kenmore 62602 Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dec 12, 2007 | Dryers
Kenmore 63942 Dryer Logo
18,962 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
