Question about Kenmore 24032\24036 Top Load Washer
Kenmore top load washer will not fill on rinse cycle
OK, so no issues filling and going through the wash cycle, but the strangest thing happens after the wash cycle is over. The washer does not fill for the rinse, instead it starts to agitate as if it the drum was already full. I have been able to stop the cycle then turn the water level dial all the way to the right and the water then starts to fill into the drum, but this is the only way the drum will fill on the rinse cycle. Is this a vaccuum issue with the water level dial? Please help if you can - Thanks --
  • therodman99 May 11, 2009
    Thanks Vic.
    You know I did have an issue a few weeks back. On the initial wash cycle, the tub would not fill all the way and I had to turn the dial all the way past the max level setting to get it to fill. Does this now sound more like it is the switch? I will remove the instrument panel tonight and take a look at it. For some reason I thought it was a vacuum action through the hose that regulated the water level. Are the switches hard to replace and would the part number be on the switch itself?
    Thanks again for all of your help - Rod
    President:
  • 1,136 Answers
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
Posted on May 11, 2009
  • Victor
    Victor May 11, 2009
    Yes they are easy to replace once you get the cntrol panel up. The part should be on the swith but, if you need the number or part, I can look it up and end you one. Just make sure the hose to the sitch is not restricted. They sometimes get little soap or lint in them.
    Vic
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't stop filling and go to next cycle automatically
if not running over ck to be sure drain is proper height and end of washer drain hose is not too tight in standpipe sound like siphoning after 1st wash and not filling to advance to rinse also be sure washer dring hose is not more than 6-8 in into standpipe
Aug 15, 2008 | Kenmore 24032\24036 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
269 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
