Question about Dryers
No heat Dryer drum turns but no heat
  • 2 more comments
  • susiew May 11, 2009
    The dryer is a Whirlpool gas dryer model LGR4364EQ2.
    In research the problem. I have no glow in the peep hole. Again drum turns just no heat. The dryer is a Whirlpool gas dryer model number LGR4634EQ2
  • susiew May 13, 2009
    I replaced the ignitor and still no heat. Checked the ignitor, senors, thermal fuse, thermostats and timer and all good. No power is getting to the ignitor. Suggestions?
  • susiew May 18, 2009
    Finally got a repairman and he found problem. Problem was actually the terminal fuse. Replaced fuse and dryer working again. Thanks for your all your help!
  • 1,250 Answers
May things can cause no heat.
If it is an electric type look for:
1. Safety device has malfunctioned or is the non-resetable type and must be replaced.
2. The timer has malfunctioned. Needs replaced.
3. Element(s) have burnt out or a wire has burnt off to the element(s) or some become disconnected.
4. Possible loss of full power. Be sure you have the proper voltage going to the unit.
5. Clogged exhaust system causing safety to activate, thus, no heat.
I would look here before going any farther.
Please keep in mind that repair by a tech may cost more that purchasing a new unit.
Good Luck and hope this gets something done for you. Please let me know what you do.
Thanks.
Posted on May 11, 2009
  • 1 more comment
  • Dennis Boxerman May 12, 2009
    There is either a safety device keeping the ignitor/ ignitioin module from coming on or the ignition module has gone bad. It's electronic so the only fix is replacing it. Another possibility is that the ignitor itself has gone bad. Again, the only fix is replacement.
    Thanks
  • Dennis Boxerman May 18, 2009
    Don't get the 2 devices confused. The ignition module is the unit that either supplies the "Spark" or power to the ignitor. The ignitor will either spark or glow red in an attempt to light the pilot, depending on the manufacturer. The ignition module can be an exposed or an enclosed circuit board. I would look there for your problem since you have indicated that everything else is O.K.
    Again, good luck and hope this gets it done for you.
  • Dennis Boxerman May 19, 2009
    I am glad that you got your situation resolved. Thank you ever so much for taking the time to touch back with me. I appreciate the feed back.
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My kenmore model 1107020290 will heat but the drum will not turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 07, 2010 | Dryers
DRUM TURNS THERE IS NO HEAT
Check out my tips and tricks for gas dryer heating problems. Click on my username and scroll down til you find it listed on my profile.
May 16, 2010 | GE DBXR463GB Gas Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
NO HEAT FRON DRYER , DRUM OK
either your heating element,hi-limit switch,cycling heat switch, thermistor,control panel, or you don't have 240 volts supplying the dryer,120volts will still let the drum turn or the timer count-down, its the way there wired
Nov 01, 2009 | Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer runs and heats but drum won't turn.
you need to replace the belt on your dryer
Dec 26, 2008 | Whirlpool LGR8648 Gas Dryer
Dryers Logo
238 people viewed this question
Top Dryers Experts
