Question about Dell Dimension 5150C (DIM515CMIN) PC Desktop
Replacement Motherboard for Dell Dimension 5150C
My Dell computer needs a new motherboard. Where can I find a replacement or something compatible.
  • 3 Answers
There is a cheaper solution for this. Get a Zotac ITX MB such as this:Zotac NF610I-D-E MINI-ITX LGA775 GeForce 7050 DDR2 for $65 at ncix.com Canada. Size 175mm X 175mm.Some filing and grinding is needed to fit it. All parts can be recycled ,but you need to buy a 775 heatsink fan for the cpu. Draw back , your XPH needs activation, you need to call MS for a key #
Posted on Jun 05, 2009
  • 27 Answers
  • 3,741 Answers
Http://www.wizzbitz.co.uk/cgi-bin/ca000001.pl
click the link directly you can get it here.
Posted on May 11, 2009
Computer restarts everytime i connect monitor to it
It sounds like the onboard video is failing. The computer should have a PCI Express x16 slot. You can get a basic graphics card to install into the machine for about $35 locally.
Jan 30, 2014 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Need new video card for dell U2424 motherboard
What is the Dell model? XPS-G2? This is a Laptop?
Jan 17, 2013 | Computers & Internet
Won't start up. Get a message on the screen - 'RADION X600 SE P/N 113-A26044-108 BIOS' This has happened before and the solution was to remove the RAM and reinsert it again. Other forums suggest this is...
Hello
Here is the image of motherboard of dell 5150c, you can remove RAM from the four slots at the left of the motherboard (pair of 2's with white and black end), you can place and remove RAM from there.
Hope it helps
Dec 21, 2010 | Dell Dimension 5150C (DIM515CMIN) PC...
I have a dell dimension 5100 desktop, I installed a new graphics card and 2 days after it wouldnt start. So im trying to find a replacement motherboard for it, the motherboard is a j8885 and im trying to...
hi there, it may not be the mother board, it may be that the graphics card doesn't have the drivers for your system. Bring it to a computer shop and they will install the drivers for you.
Jan 30, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I changed the CPU fan on Dell dimension 3000 but it does not run.
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Jul 12, 2009 | Dell Dimension 3000 PC Desktop
Upgrade a dell dimension 4500-p3 motherboard to a duo or quad motherboard
You can do this with case modification as well as a new psu as Dell used proprietary mb's, psu's & cases on this model Dimension. To tell you the truth it would probably be cheaper and easier to pick up a core2duo or quad barebones kit than trying to modify the Deimension. Just my opinion. Remember Dell psu's are not wired the same as industry standard and their motherboartds in these older units are not top quality. Hope this helps you out.
Jul 08, 2009 | Computers & Internet
Memory Upgrade Attempt Causes Computer Not to Post
Seeing as the message is indicating a problem at one of the timer checkpoints, fatal is probably an accurate description. You are most likely looking at a motherboard replacement scenario. I've seen improperly seated memory modules toast timer circuitry on old boards back in the days when most of the timing circuitry was constructed from discrete components, not entirely IC-based timing solutions, but I have never seen it happen on modern boards.
Apr 10, 2009 | Dell Dimension™ B110 PC Desktop
Dell dimension 5100 motherboard
I would try asking dell.go to www.dell.com lala linda
May 18, 2008 | Intel D845GVSR Motherboard
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5150C (DIM515CMIN) PC Desktop Logo
1,140 people viewed this question
Alun Cox
