Washing machine, bang crash
The washing machine is a front loader. It is an LG, it seems as if the barrel has broken off its supports it still rotates but flops around and mackes alot of crashing sounds.
My inner drum was bouncing around too. I removed the inner drum (there is some work involved) and found a broken spider. The shaft installed on the spider had come loose. I replaced the spider assembly, the bearings and seal. works better than it has in a long time. The parts cost $175.00 at repair clinic.com (great experience with them). It seems it may be easier to replace the entire outer rear drum instead of the bearings alone because the bearings are really tough to remove and reset without the right tools and it is really easy to damage something if you beat them out and back it. The outer rear drum assembly comes with the new bearings in place and hoses and the rear shock absorber installed. It's a great deal at $145.00 from repair clinic. I opted to replace just the bearings to save a little money and dis-assembly but can't say it was worth it. I'm a first timer with appliance repair and learned a lot with this experience.
Posted on May 11, 2010
    President:
  • 1,136 Answers
It sounds liek a shock/support is broke. Remove the lower front panel after you UNPLUG the washer and you might be able to see what is wrong.
Hope this helps.
Thanks
Vic
Posted on May 11, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
LG Fuzzy logic 5.5 WFT552 goes to spin and then bangs around horribly before going back to the rinse cycle??? WHY?? Can anyone help please?
Could be broken spring unplug...remove top cover if front loader /inspect check drum.....make sure its level on the floor
Jun 27, 2012 | Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
My lg front loader washing machine would not start at all ! it seems like there's no power at all ! what should i do ?
check power at wall outlet us lamp to test for power
check power cord look for broken or loose finger in plug
Jun 09, 2011 | LG Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Pipes are banging
you can purchase a "hammer arrestor" from any major hardware store and have it installed which should cure your problem.
Feb 11, 2010 | LG WM2277H Front Load Washer
Sears 440723 front loader bangs when spinning. Tub rotates smoothly but seems very loose
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore 44102 Front Load Washer
The basket is tipped forward
Most top loaders have 4 springs supporting the drum. In your case 1 spring has broken or come away from it's mount.
May 09, 2009 | Whirlpool LSR7333 Top Load Washer
Banging and small leaking
Is this a front loader you have? the banging could be broken shocks.
Mar 11, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
