LG L1915S 19" LCD Monitor
Problem for LG L1915S 19" LCD Monitor
LG W1952T LCD monitor power save mode during bootup?
By heartless500 on May 11, 2009
Have an new LG W1952T LCD monitor - when starting pc, monitor goes to digital power save mode during bootup & I cannot get into/see the bios setup (need to get in to set up new memory sticks). All pc power saver options are turned off/set to 'never' - monitor does turn 'on' when the logon in screen comes up...
<b>How do I stop it from going into power save mode during bootup???</b>
system (about 5 yrs old):
Abit KD7-raid w/AMD athlon 1.3Ghz
512Mb ram (trying to upgrade)
WinXP Pro w/SP2
Comments:
May 11, 2009
- Problem solved by calling LG customer service - Bootup is analog and will not show when monitor is in digital mode - it doesnt recieve a digital signal at that point...go figure! by hooking up the analog (VGA) cable i was able to see bootup fine. Neet thing is I can have BOTH cables hooked up (only works if you have both connections @ vid card & on monitor) and switch back and forth between digital & analog as needed by pressing the "source" button! Hope this helps someone else.
Same Problem
May 15, 2009
-   i have the same problem with this "power saving mode" thing.. can you pls explain to me more briefly?,, on how to fix this problem? Thank you.. -   Guest
Best Solution
posted on May 12, 2009
Helpful)
heartless500
Rank: Apprentice
Rating: 88%, 6 votes
called customer service - see other post for details
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LG L1915S 19" LCD Monitor
Questions and Unsolved Problems for LG L1915S 19" LCD Monitor
Do you recommend LG L1915S 19" LCD Monitor?
Answer
Answer
I have a LG Flatron W2043T monitor that wont turn on, just says analog power saving mode. Can you... (More)
Answer
monitor does not turn on. Power switch appears not to work
Answer
on the desktop i m having vertical column on the left most having the icons as well
Answer
when i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop,... (More)
Answer
my 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Addison, TX
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
