Question about Dryers
My dryer takes 3-4 full drying cycles to completely dry.
My dryer doesn't seem to be doing it's good job in drying. It takes 3-4 full timed cycles to completely dry one load. I am handy with a set of tools. What would you suggest?
  • 1,250 Answers
Since you do have some drying hapening, it is probably a lack of total heat.
Most all dryers have 2 heating elements. One for low heat and both for hi heat. Sounds like you lost one of the elements.
On electric dryers, look for:
1. Safety device has tripped and not reset or has malfunctioned.
2. An element has burnt out. Or a wire to the element has fell off or burnt off due to loose connection.
3. Exhaust system is clogged or restricted, causing safety to active. This stops the heating process. (Don't forget the internals of the unit being clogged too.)
4. Not getting full power to the unit. Reset breaker and verify that full power is to the unit.
(Usually somewhere between 208 to 240 volts, depending on where you are at and the manufacturer of the machine.)
5. Timer has malfunctioned and needs replacement. This does effect power to the elements.
Check these out and let me know how you come out.
Please keep in mind that there is the possibility that a new unit may be cheaper than repairing the one you have. New units have warnanties too.
Choose wisely grasshopper. And Good Luck on your getting it going.
Posted on May 11, 2009
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer takes 2 or 3 cycles to dry
A Whirlpool dryer either heats or doesn't heat . This problem is an indication of a blocked vent hose , from the rear of the dryer to the outside vent outlet . Try removing the vent hose from the back of the dryer and dry a load , to verify this problem . Wet lint inside the hose also means the air cannot escape to the outside .
Apr 18, 2010 | Whirlpool LER4634J Electric Dryer
I have model # eed4300tq0 it takes 3 times longer to dry than it use to. it use to dry in one cycle on high heat,now i have to use high heat 3 times to get completely dry. dryer is only 1 and a half years...
Blocked vent hose . Disconnect the hose from the dryer and dry a load . If dryes ok , check the vent hose and vent . Make sure there is good air blowing out the back .
Aug 08, 2009 | Estate TGDS840JQ Gas Dryer
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
The dryer works but it takes over one cycle to completely dry clo
Hello , I can help , get a good flashlight , lean over the dryer to get a good veiw of the back where the duct connects to the unit , make sure there are no twist or kinks in the duct , if there isnt the vent where it vents outside is probably clogged or full of lint. Hope that helps. good luck
Dec 30, 2008 | Whirlpool LEQ8611L Electric Dryer
Taking long time to dry
An innovative dryer, the General Electric Profile Harmony DPGT750GCW(gas) / DPGT750ECW (electric) has the ability to communicate with its matching washer via the manufacturer's CleanSpeak system. More specifically, this Profile dryer is wired to the Harmony washer, allowing electronic communication between the two. If you're wondering what these two have to talk about, the answer is simple. They talk about your laundry and how to dry it.
CleanSpeak works by transferring information about a wash load to the dryer and setting it automatically so you don't have to make any. Machine-determined optimal settings for each load are selected by the information about each load size and type. Your job is simply to place the wet laundry in the dryer and press start.
That is where the problem begins, when you interrupt the drying cycle. The machine is then rest to small load dependent on when the interruption occurred. The dryer computes the duration of drying time again the wash load. Each time you load the washer, the dryer is computed to using the shorted time. Thus, we have double cycle.
you will need to override the automated settings and enter your own preferences. Doing so can be a bit complicated, as this machine has lots of intricate, detailed controls that may take some getting used to. In fact, we suspect that's why this dryer is designed to be set by the washer. Having individuals set it, with all its options, takes some patience. The good news is that once you have manually set cycles you have found to use often or like, you can enter them in the memory, allowing the machines to set them your way in the future.
Option is to unplug the machine and wait minimum of 2 minutes and plug in the machine, hit power on.
I would recommend unplugging both machines, and rest both to factory default.
good luck
Nov 05, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer doesn't dry very well.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Why are you talking about it rather than acting on it?
You need service to fix it or perhaps if its old trash it and buy new!NOT MAGIC CHEF!
If you buy for price only you will change APPLIANCES EVERY 5 YEARS!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
154 people viewed this question
Top Dryers Experts
