The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&YUHG
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
I have the same problem - washer seems to run through most of cycle and then stops with lr error code. If I just run the spin cycle the water gets pumped out, although I am not sure the machine is spinning.;.......any suggestions?
Mine does the same thing! UGH!!! It is less than 2 years old!!!!
Washer runs thru some cycles but stops randomly with an lr display. It took some effort to get the machine to empty the water out on the spin cycle but did not actually spin. Also took longer than usual for door to unlock so that I could unload wet soapy clothes.
