Question about Refrigerators
Where to buy defrost heater here in the Philippines
I have problem with my no frost defrost heater, I dont know where to buy repacement part here in the Phiippines. Please advise me where to buy or order the "defrost heater coil".
    Guru:
  • 1,524 Answers
Www.bcaparts.com
Posted on May 11, 2009
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My fridge works fine but sometimes the freezer will stop working and you can here a sizziling sound coming from the back like water dripping and hitting something hot. I unplug and plug back in and it...
Hello, welcome to FixYa.
This is just the normal operation...specifically the defrost cycle every frost free unit must cycle through every 8-12 hours.
You are correct, the sizzle is water (from the melting ice) dripping onto the defrost heater. It is all normal so no need to worry.
Thank you for choosing FixYa today. Please take a moment to rate your experience here.
Regards,
Macmarkus :)
Aug 15, 2011 | Kitchen Ranges
[frozen heat pump coil], freon checked,contactor replaced,outdoor defrost thermstat repaced..worked all of a very cold december,temp rose to 50 degrees for 2 days,7 once temp dropped again,coil froze up...
THE ONLY THING THAT CONTROLS THE DEFROST CYCLE is the defrost thermostat and the actually defrost control board. along with making sure there is enough freon in the system to switch the unit over and move the reversing valve when it is time... if they have changed the defrost thermostat and you are positive the freon level is good the it appears you may have a bad board on the unit.... be advised the unit should frost up in cold temps and is normally to have frost built up on it then will go into defrost mode. if the unit is freezing over then yes you have a issue.
good luck to you
Jan 03, 2011 | Heating & Cooling
Our side by side GE Refrigerator feezer is defrosting and the refridge side is barely cool. The fridge is only three years old. what should I do?
Look at the back wall inside the freezer from the middle down, if you see frost evenly on the back wall then the Defrost system has failed.
Posible fixes, Defrost limiter, Conttrol board bad, Heater Bad, Defrost timer bad.
if you did see the frost you could buy some time by defrosting the evaperator with a hair dryer. (( if you dont know what your doing the please call a appliance repair tech ))
Sep 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
GE Fridge not cooling well, frost in freezer,back wall and coils
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 17, 2009 | Refrigerators
GE TBX18BLJ --Freezer comp frosts/ices up. Defrost
The next step would be to unplug the refrigerator and remove the rear panel and defrost so that you can unplug the defrost heater on one end and check the continuity. 305175 Defrost Heater and defrost thermostat Part number 3489. If you change the defrost heater you should also change the defrost thermostat. Let me know the results. Remember above 60 degrees the defrost thermostat will show open with your OHM meter. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 15, 2009 | GE Refrigerators
Have done these tips, but...
A defrost termination thermostat could be the trouble. It could cut off the defrost heater before the temp is up high and long enough to clear out the water from defrost. the stat is either the size of a quarter or a dime depending on which you have and it is located usually on the evaporator coil. If you inspect it after running for a week after your lastm clean up it will also tell you if the coil is completing defrost. look for signs of the frost starting to build up on the evap inside coil. If it is starting this also and is most of the coil covered with frost the defrost stat and timer bothe should be replaced if you dont want to have a repeat problem. If the frost is really thick you need to check the heater as well. A bad heater usually wont last a month though. 2 weeks in 30 to 60% humidity is about all it can handle. If your humidity is lower or you dont open the doors every day 4 to 8 times or more it may last a month also. All this is assuming you ahve a self defrosting model though.
Jun 17, 2009 | Whirlpool ET1FTKXK Top Freezer...
GE sxs defrost problem
How long does it take for the frost to build up, improper placement of the bi-metal will cause a defrost issue by not letting the heater stay on long enough.
Let me know how you make out.
Thanks,
Bill
Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
