Question about Dell E207WFP LCD Monitor
Dell E207WFP Main Menu keeps popping up on the monitor on top of everything. You cannot work until it goes away, but it pops up every few minutes. The mouse is behind the menu so you cannot click anything on the menu. How do you get rid of this?
  • Frank Zhang
    Frank Zhang May 11, 2010
    can you click the menu key at monitor buttom? any change on popping stuff?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hello..its just a sticky tack switch u need to clean all tack switch or try to align the body/frame of LCD..Thanks..Good Luck..^_^
Posted on May 11, 2009
Main menu on the lower right hand side keeps popping up
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
Jan 27, 2013 | Gateway FPD1975W 19" LCD Monitor
Box keeps popping up
you have to explain the issue in more detail. Boxes popping up on Windows PCs is normal.. they can be warnings, offer selection options, they can be information to your request, etc.
Jul 26, 2011 | Dell E207WFP LCD Monitor
OSD Main Menu appears randomly and uncontrollably /flashing. Power Button does not always work. Need to keep clicking unti works.
hello..the problem is just sticky tack switch's so try to clean or re-align the frame/body of LCD..Thanks.Good Luck..^_^
May 08, 2009 | Dell E207WFP LCD Monitor
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Menu keeps popping up!
I had this same problem with the Main Menu coming up on my Dell Monitor E171FPb and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
May 25, 2008 | Philips 42PF9431D/37 TV
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
Main menu / positioning /
Sounds like a button is sticking. Does it seem too sensitive? It should give a little resistance when pressed and have about 0.1" of travel. Try gently prying outward on the offending button with a pin or needle. If you're comfortable taking the monitor apart, do so and check the alignment of the menu buttons.
Oct 03, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
HP 1530 Onscreen Menu refuses to go away
the button is bad on it the select OSD button
the cable is bad, and tells you out range, no signal, or other cable dead errors or in sleep mode. can be PC, cable or monitor
id have to see your screen to wax smarter.
unplug monitor from power and pc
let sit for 1hr.
the plug it in all alone
does OSD pop up> is there an error
if no error there, the monitor buttons are broken,
Jun 10, 2017 | HP L1530 (Carbonite, Silver) 15" LCD...
Dell E207WFP LCD Monitor Logo
988 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
