Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
My lawn tractor does not cut level on both sides of the deck
  • 246 Answers
Hello:
This Problem is Usuall Caused by 1 of Several Problems.
1- The Spindle/Mandral Bearings are Bad Allowing the Blade to be Slightly Lower than the Other Blade and Requires Replacing.
2- The Blades Require Replacing.
3- The Deck Needs to be Leveled. There are Deck Level Adjusters on Each Side of the Deck.
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
My Craftsman 42" lawn tractor
I would suggest checking your owner's manual. There is a leveling process and my Craftsman wasn't leveled at the factory. Once I leveled mine, it cut fine. If you can't find it in your manual, google leveling craftsman mower deck.
May 14, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
42 inch mower cuts uneven, what is the problem?
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Jun 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cuts lower on side
first and foremost! make sure the tire pressure is correct in ALL TIRES and then level the deck.
May 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Can't level deck.
try checking the blade spindle to see if there is any play (up,down,left,right) hope this helps
Jul 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears Tractor Mower 42" is cut cutting lawn in two uneven strips
First, check the blade, it may be bent. If not, there is an adjustment nut (9/16) on each side in the middle of the deck hanger bracket. Get on level surface and screw each up or down to get blade tips the same height on each side.
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The highest deck setting cuts my grass down to one inch.
leveling bolts hang from each side deck by frame...tightened up and level...will give you some more room....be sure the blades are not bent.
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
RIGHT SIDE BLADES CUTS LEVEL, LEFT SIDE DIGS INTO THE GROUND
the right side cuts level but left side doesn't well the answer i have would be that someone stepped on the deck which will cause the adjustment arms to bend & deck will not be level or the only other thing it could be is the blades could be bent as well if i can further help e-mail me @ wadembly@aol.com thanks ,wade
Jun 08, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
19.5 hp 42 in cut craftsmen lawn tractor.I got from grandmother,blades were bent got new sears blades still digs into ground and doesn't cut in middle,do I need a new deck?
No,You need to park on a level area and lower the deck to it's lowest setting and adjust the deck with the large butterfly nuts on each side,just under the foot pan,just loosen and let the adjusters fall into place,Tighten back up and it should be set.You may need to do this more than once.
May 11, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
101 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
