Question about Amana DLE330RAW Electric Dryer
Me GE elec. dryer is screeching, how do I solve this problem
  • Amana Master
  • 1,144 Answers
First, stop using the dryer. It is telling you "I'm broken".
Several things can cause the noise you are describing:
1. Belt is slipping. Lost proper amount of tension on the tension pulley as spring has become weak.
2. Rear drum bearing has rubbed completely through and the drum is now riding on the metal support, This can cut into the drum support and trash it.
3. Tension pulley has got bearings that have gone dry (bad). Fix is to replace pulley.
4. Chance that the bearings in the motor itself have gone dry (Bad). Some you can oil and some are sealed. In either case, if they are making this noise, they are probably no good and motor needs replacing.
Good Luck and let me know how it turns out.
Posted on May 11, 2009
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
GE DRYER MAKES A HIGH SCREECHING NOISE WHEN DRYING BUT NOT EVERY TIME AND SOMETIMES DOES NOT START TILL HALF WAY THRU DRYING OR SOMETIMES NOT AT ALL?
More than likely a bad wheel and or drum support. However there are a lot of different GE dryers so the model might help to narrow down your problem. The model number should be inside the door of the unit.
Feb 25, 2011 | GE Dryers
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
My GE Model# DBXR463EB0WW makes screeches and
Open the door and there are some screws holding the top on. Then you remove the front after removing a screw on each side. But first UNPLUG it and remove a cover on the lower back to get the belt off the tensioner.
Feb 13, 2010 | GE Dryers
Dryer screeching noise GE - DVLR223ET1WW
Remove the back panel and check the brake to make sure that it is not staying locked to the drum.
Jun 01, 2009 | GE DVLR223 Dryers
Screeching Drum
My machine did exactly the same thing until the belt snapped - and it's a very painful noise!! I'm about to replace my belt and if this solves the problem I'll let you know.
Dec 15, 2008 | Candy CDC266 Dryer
Ge dryer model# dvl223
This may sound silly but did you check (or have the means to check) for voltage at the outlet? The absolute bottom line is that if there is no power.......you get the rest.
Jul 27, 2008 | GE DBSR453EBWW Electric Dryer
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
Amana DLE330RAW Electric Dryer Logo
149 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
