Question about Eclipse DA7232 Car Audio Amplifier
Strange Starting hum as amp tries to turn on?
Ok I really love this amp first off. But Ive had tons of troubles with it also, it all started when I was cleaning my car and accidently completed the circuit where the speakers + and - connecr after that it made no sound at all, so concerned took it to a repair guy who took forever to repair it. So I just got it back a couple days ago and hooked it up an to my 3 eclipse allum subs. But yet again I can notice the amp tries to turn on but is also greeted by a strange humming and crackling noise as the amp turns off to deaf ears:(
    Problem Solver:
  • 18 Answers
First of all you need to look at the specs on the amp and see what ohm load rating it runs at. for example  (4 ohms @ 200watts)   and check your configuration because if you go below that rating  for instance if the amp only can do 4 ohms and you parallel them speakers down to 2 ohms  the amp will go nuts and blow up.    After you find out informations about the amplifier ohm your speakers out with an ohmmeter and see what resistance you have on your single / dual coils   and wire them up to proper configurations so that your amp and subs are matched.     ALso check your RCA'S  For signal problems.
Posted on Oct 13, 2007
Ford ka not starting
starter or solenoid is bad . hum might be fuel pump building pressure
Sep 27, 2016 | Ford Ka Cars & Trucks
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
I am having trouble starting my 1991 ford mustang lx 4 cyl 3.2 l when it dose start it runs really ruff and when i put it in gear and press on the gas pedal it does not accelerate but acts like it is not...
I would check the timing could have jumped a tooth on the timing belt/chain. Also check the rotor in the distributer make sure that it is not worn out. I have also seen a plugged catletic converter cause big time power loss and really strange problems
Dec 14, 2013 | 1991 Ford Mustang
My teac pa688 plays only on 45 now the turntable wont start just hums thru amp
If it's a belt drive the belt could have become slack or something and slipped off it's correct position.
Mar 30, 2013 | Audio Players & Recorders
Not getting fuel will not start put startingfluid in air intake motor will try to start
Fuel pumps bad! Unless you have a clogged fuel filter!! Have great spark?
Sep 04, 2011 | 1989 Mercury Tracer
MTX SW2 Power Surge Damage?
Try the fuse first then if no problems alls good , but if it still hums it could be the crossover board inside , if you love your sub like i love mine you will just replace the crossover if need be . Smirf 617
Jun 12, 2009 | MTX SW2 Subwoofer
1983 chevy half ton head and tail lights wont turn on
Strange,something should com on.Are you sure you got power to the lightswitch?
May 05, 2009 | Silver Jeans TVR Tuscan Wireless Street...
Eclipse DA7232 Car Audio Amplifier Logo
106 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
