Sony vaio ra828g, xp sp2, dead mouse and all usbs
Recently went to start up my desktop and it starts but all of the usb are
dead, including the mouse so I can't do anything.
Starts in safe mode but dead mouse won't let you select any options or
even system restore. Tried unplugging everything that is usb, tried all
the ports including not using the usb hub, but even plugged directly into
the machine usb front or back, no usb works.
Can't select any menus or do system restore, so what do i do?
  • 2 more comments
  • earlh20659 May 11, 2009
    I did try plugging and unplugging the mouse into every usb port,
    but no port works!
  • earlh20659 May 12, 2009
    here's some more information I've discovered,
    the mouse works a short time when opening in safe mode
    but then locks up....I don't have time to open the device manager to look at the ports etc
    Interesting though, that during startup the usb hub is all lights on green but when the windows xp logo shows up the hub goes black
    That suggests to me that all the usb ports work, just that during the startup they get shut off some how....
    would love to do system restore but the mouse stops working before i can select anything.......
  • Frank Zhang
    Frank Zhang May 11, 2010
    are you sure your mouse port works ok or not?
    do you check the hardware managment is there USB divice driver there?
  • Frank Zhang
    could you unplug and plug in the USB mouse in winowds see does it work?
Sony vaio touch screen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
I have a HP Pavilion G70-250US Notebook that suddenly starting having USB recognition issues. It started with the USB receiver for my wireless mouse. Suddenly it stopped working and I started getting...
no operating system even stated.
Xp/vista/w7/w9/w10/ linux ,what.... must we guess?
is your internet connection working? it must or PNP will be near brain DEAD ,do that first.
ok guess w10.
why not see if OTHER USB works first
barrow a real mouse not that battery dead wireless wonder mouse?
get a real mouse
make sure that works
then put in a new battery in your wireless mouse
RTM it tells you how
USB tests, all so obvious.
use real desktop key board , that work
or USB memory stick , add file to it, see other files you have there>?
only clues here is USB dead, 2 months old.(means new? or new to you?)
next,
in w10
go to CP
then go to device manager
be ONLINE
see yell or red error there that driver stack?
bingo bad driver
reload any that are bad.
end story
google how to reload a windows 10 driver, be like 10,000,0000 hits.
Mar 15, 2017 | HP G70-250us Notebook
USB Port not Detecting any Devices
Before i can suggest any steps i need to know since when u have this pblm and what are the softwares and hardwares you had installed recently,please revert back with details for more assistance......:)
May 16, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Driver problem
i will give you a link that will be help full
http://www.techsupportforum.com/hardware-support/driver-support/186276-sony-vaio-pcv-rs720g-no-drivers.html
please rate if i was helpfull
Apr 20, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
USB 2.0 slot on Sony Vaio PCV-RX860 does not work
Reinstall drivers for the usb ports. Eather on the company site or from your recovery disk that came with the system.
Feb 15, 2009 | Sony VAIO Digital Studio PCV-RX860...
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
No sound devices on my sony vaio VGN-CR322H laptop
Pl check the whether all driver from OEM have been installed including MB and try to reinstall the driver it should work fine. or reinstall the SP2 for win XP. then install the OEM driver again, this should work, else there might be hardware problem.
Aug 20, 2008 | Sony VAIO PCV-J200 PC Desktop
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
