Question about Intel Pentium 4 540, 3.2 GHz (bx80547pg3200e) Retail Processor
When we login on google earth.lnk my desk top goes power off.Why tis is happening & wwhat is the remedy?
    Master:
    Sergeant:
  • 461 Answers
Check your RAM./Increase the RAm capacity or check your registry refer below link
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
Posted on May 14, 2009
Hi, Dave again - not sure if my problem was visible or not?
you may try to fix it by doing this:
http://www.sevenforums.com/tutorials/19449-default-file-type-associations-restore.html
If it does not help, reply and I will give you further instructions.
Mar 29, 2013 | Lenovo Computers & Internet
HP s3420f BSOD Vista
Vista is a DEAD,OS. (ended now)
got the HP VISTA install disks, or waiting for this moment to happen
as all do.
seem screens bad too. try another borrowed DT screen as a test? easy no?
but.... both main processors , shut down. IF?
what if the GPU chip is overheating, ever do DUST bunny SERVICE
(vacuum it out?) no PC lasts for 10 years and not fill with dust
not one. ever.
BSODs
  1. bad memory chips, try all sticks 1 by one, to prove it.
  2. corrupted VISTA. or Virus infected as most are this old.
  3. low power, power supply in unit weak or noisy.
  4. bad HDD, disk errors, run check desk yet?
  5. reload VISTA fresh? HP media set not MS.
  6. or worse there is always worse.
Apr 07, 2017 | HP Pavilion S3420F Slimline Desktop PC
I have just purchased a new electric cooker. The old one had three terminals in the back, one each for live, neutral and earth. The new one has three marked live, two marked neutral and one marked earth. I...
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Nov 09, 2010 | New World 70TC Electric Single Oven
Creating desk top shortcut
just drag the gmail icon from the address bar and drop it on your
desktop.
OR
- right click on your desktop
- click on new --> shortcut
- type "https:\\mail.google.com" (without the quotes) in the field
when it asks for the path
- click on "Next"
- type a name for the shortcut, e.g. "Gmail"
- click on "Finish"
This will open the Gmail login page in your default browser.
See if this was helpfull.
Jun 16, 2010 | Microsoft Windows Vista Home Premium with...
Is the Samsung Zirez Pleomax 80GB Portable Hard drive compatible with Mac's. Reason being that my inspirion laptop now doesn't recognized the portable drive. Worse case if the drive is faulty is there a...
Yes, the portable harddrive is compatible with a MAC Product Features
  • Quick & easy to install Features USB 2.0 &1.1 interface connections allowingit to freely switch roles as local storage device
  • 2.5-inch External HDD
  • Fast & Small 480 Mbps for high-speed performance and smooth data transfer Ultra-slim attractive design everybody wants to have
  • Compatible with PC, Mac & Linux
  • Portable Carry & use either at your desk or on the go Simple & convenient plug & play automatic recognition
http://www.amazon.com/Samsung-Pleomax-Zirex-Portable-UHD2-5-80G/dp/tech-data/B000BB69AS/ref=de_a_smtd/179-8912138-6919333 This error is probably caused by a bad shortcut. The ".Ink" you refer to is really ".lnk" (the first character of the extension is a lower-case "L," as in link, not an "I"). Shortcuts use "lnk" as their file extension.
This kind of thing can happen if you install software from a networked drive and then later detach from that network, which is a common situation if you use a laptop computer that you disconnect from your office network and take home. To find the shortcut, follow these steps: Open Windows Explorer and press Ctrl-F (hold down the control key and press F) to bring up the Find dialog. Select "Local Hard Drives" in the Look in dropdown, and enter ".lnk" (or whatever the error message reported for the name of the bad shortcut) in the Named field. When you click the Find Now button, Windows will search your hard drives for the shortcut and display what it found.
Jan 09, 2010 | Samsung Zirex Pleomax 80GB Portable Hard...
Mi copiadora sharp AR5125 tiene codigo U6
code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
Nov 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
GOOGLE EARTH LOADS AND THEN IMMEDIATELY SHUTS DOWN
check if your graphics card is up to the job you can do this on your desk top right click and goto the bottom option then disply opptions and check the graphics card if its a standed one you will have problems loading hope this helps
Oct 26, 2009 | Computers & Internet
Crown PSA-2 power amp. Right after turning power on with volume controls all the way down, the amp continuosly thumps the woofers (alternating from the right to the left. This just started to happen. No...
Hi! The thumping motion is usually caused by faulty cross-over voltage biasing. What this is is simple; Power amps of high wattage are usually constructed of two similar but opposite polarity amplifiers ;one drives the top (positive) part of the sinusoidal and the other drives the bottom.
The simple causes that need to be eliminated are
1) Earthing :-check earthing to ensure no earth loops
2) Check the Power fuses:- usually, the supply of power to only one part of the amplifier causes thumping motion. The power section in these designs have a positive and negative polarity eg.=80V-0V-(-) 80V
3) Disconnect the speakers and check the power supply Voltages across the output stage sumettry for more details visit
http://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
Dec 02, 2008 | Audio Players & Recorders
1993 eb ford falcon
You have a bad earth problem. Reccomend check sender unit in tank. Guage wire is Yellow with a green trace.
Jul 18, 2008 | 1983 Ford Fairmont
Intel Pentium 4 540, 3.2 GHz (bx80547pg3200e) Retail Processor Logo
411 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
