Question about Goodman CLQ36AR49 Air Conditioner
Fan making noise squeeking etc
Cost for replacing fan motor goodman airconditioner split unit
  • Samuel Charles Spriggs May 11, 2010
    The squeaking is probably just a lack of lubrication. Try machine oil on the fan motor shaft/bushings/bearings/pulley shafts/etc.. This may stop the squeal.
  • Anonymous Mar 13, 2014
    ticking noise in small fan motor to exhaust flew pipe to roof
    Scholar:
  • 152 Answers
Ok not sure which fan or country your in but here in Australia if its the out door fan, should not cost more than $1200  if its the indoor roughly the same depending on access , may cost a bit more for labour but ... ok fan only cost indoor $600 outdoor $450 to $800 depending on weather the fan blade is seized or not, if its seized then a new blade can set you back To the $800 buck mark including the motor
Posted on May 11, 2009
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
Centrex airconditioner
HI,
Can you please give the model no. so that i can give you the right parts.
Waiting for your reply.
Apr 08, 2008 | Heating & Cooling
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
I have a lasko floor/ wall mount fan model 2264 QM and when I turn it in it makes a SQUICKING noise, what can I do to stop that
squeeking noise from a running motor more often comes from a worn down motor bushing and shafting, this will later lead to the fan not running at all due to stuck motor and may burn the electric coils , causing more damage. While still at the squeeking stage m have the shafting and bushing replaced.
May 09, 2014 | Dryers
I had a goodman ARUF split system installed 8-25-09.Since then the heat exchanger blower motot replaced,cost $602.75,outdoor condenser unit fan motor to be replaced $592,00,recommend 5/8xing...
Hello, Usually it has to do with the quality of the install and the brand. If it was not installed properly from the beginning then the equipment will fail prematurely. As far as the heat exchanger goes I have replaced many heat exchangers on Goodmans after 3 years being installed, Goodmans are prone to bad heat exchangers.
Mar 05, 2011 | Goodman Heating & Cooling
We have a goodman split unit, It was below freezing the other morning and the unit had a squeaking sound when it started up. Now it has warmed back up, the unit is sounding as if it's trying to kick off...
The symptoms seem to be related to the main blower motor and/or it's capacitor. Turn the system off for a couple of minutes and then turn just the fan on while the thermostats heat setting is in the off position. If the lights still dim then replace the motor and capacitor. The clicking noise is the fan relay.
Dec 17, 2010 | Goodman GMS807034ANA Heater
MY unit is not cooling. fan in not turning, top
It sounds as though your outside motor has failed. If you have a long shafted screwdriver, you can attempt to spin the motor to see if the motor has seized up. Caution should be used as the motor may start if the unit is calling for cooling when you attempt this. If you can manually start the motor, then chances are the capacitor has failed.
Check it out and replace the motor if need be. That should get you back up and running.
May 26, 2010 | Goodman CKL24AR24 Air Conditioner
I have a cple18-1c at my home. it is making a
Fan motor is out or possibly the capacitor to the fan is bad. Would have capacitor replaced first then replace the motor if the capacitor didn't solve you problems.
Good Luck on repairs
Dave
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Goodman CLQ36AR49 Air Conditioner Logo
118 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
