Blows electrical curuit
All of a sudden my washing machine blows the elctrics in our home, crackles, sparks then smells of burning, then trips fuse
    President:
  • 1,489 Answers
It has a serious electrical short, probably in the motor. It needs a service call, unless you're up to doing it yourself. Sounds like it could be very involved.
Posted on May 11, 2009
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
Hoover DYN 8144D Electrical fault/Crackling noise when power is applied
get a service technician to check it over but there is a very serious problem that may be safety related
Sep 07, 2015 | Hoover Washing Machines
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine trips my electricity as its about to spin,
There is almost certain to be a small leak which could be from a variety of things. The water sounds like it has found its way onto your motor windings. Once it starts burning,carbon is left behind on motor.The decision to replace motor and possibly hole in drum is the question.Need to weigh up if a new purchase is possibly the right way to go. Remove covers to see if the source of the leak is visible.
Oct 02, 2009 | Tricity Bendix AW1000W Front Load Washer
Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
Dec 07, 2008 | Roper REX4634KQ Electric Dryer
Washing machine
Check the brushes in the motor. They've probably worn down and need replacing.
Oct 06, 2007 | Washing Machines
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
