Question about eMachines D3415 PC Desktop
How can you check if you have a faulty ram? - eMachines D3415 PC Desktop
  • 413 Answers
How to diagnose bad RAM Does your computer emit endless beepsduring bootup? Does your PC crash for no apparent reason at randomintervals? Or you get blue screens of death with errors such asIRQL_Less_or_Not_Equal? If so, then it is very likely that there is aproblem with your computers memory (RAM).
visit this link to LINK
Posted on May 11, 2009
Asus AT3NT A-1 motherboard. after plugging in the power supply green LED comes on ok. switch on computer DVD drive LED flashes on as normal, CPU fan comes on as normal, it all seems ok, but no Video...
May be your RAMs are faulty. Or your VGA is faulty.
Remove RAMs and clean the RAM slot. Re-insert the RAMS. Restart the computer and check.
If it doesn't work, replace RAMs and see.
Sep 11, 2011 | ASUS AT3N7A-I Atom Dual-Core 1.6GHz/...
My 2nd memory slot for ram is not working can this be repaired?
Beforeyouassume the 2nd RAM slot is faulty check the following.
When instaling RAM in the 2nd memory slot this RAM may not be compatible with the RAM in the 1st memory slot or the RAM may be faulty.
Try and use the same make, speed and size RAM modules.
If the RAM slot is faulty, chances are it cannot be repaired.
Aug 27, 2011 | Computers & Internet
My system doesnt see the ram i installed,(512x2) its perfectly compatible,still it only sees 448 MB out of 1024.i updated bios and everything.is it coz i am using the on-board graphics adapter?help me out...
It looks like your computer is seeing only one 512Mb RAM module. Your computer uses shared RAM - 448Mb RAM is available for the computer and 64Mb is reserved for video RAM (448 + 64 = 512Mb) of RAM.
One of the RAM modules may be faulty. To determine which RAM module is faulty, remove both RAM modules and insert one RAM module at a time to determine the faulty RAM module.
If both RAM modules are OK then -
Some computers do not like mixed RAM modules from different manufacturers. Try using the RAM modules with the same make and type/speed.
Jun 14, 2011 | Computers & Internet
Toshiba satellite has pink screen .
Pink screen (with vertical lines) is due to faulty RAM. As far as my experience tells me, if you are having two RAM Chips, one of them could be the faulty one. RAM modules can be checked/replaced by opening the cover located underneath the laptop. If you have two RAM Modules, try using one at a time to identify the faulty one. Make sure you turn off the laptop, remover the adaptor cord and battery before removing and reinstalling RAM.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | Computers & Internet
I upgraded RAM to 2Gig (2x1024), but Notebook still only recognizes 1024MB. How do I maximize RAM?
USING XPThere may be a faulty RAM.
Check the ram by inserting one each at a time if your laptop doesn't start with one of the ram that ram would be faulty.
Hope this helps.
Please feel free to ask any further.
Mar 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Blue screen. 0x0000008e (0xc0000005,0x80409A88,0xf789e360,0x00000000.
This error occurs due to the following reasons: Faulty RAM, registry errors, incompatible drivers, hardware failures, faulty BIOS configuration, Viruses.
Follow the steps below to avoid the BSOD error message occurs again.
Check whether the RAM installed in your computer complies with the motherboard specs. Replace the RAM if needed. You can also check the systems with a friend's RAM to know whether the error message is due to RAM.
Use a free registry cleaner/fixer software available to clean/repair your windows registry. (Ccleaner is good at this)
Do not install incompatible device drivers. Install only Microsoft Signed drivers. Update your existing driver software from the corresponding device manufacturer's website.
If you have installed/changed new hardware, check whether it is supported by your system. Also check whether it is installed properly. If needed test the systems without the faulty hardware. Check whether you've installed correct/signed driver software for that particular hardware.
If you have reconfigured your system BIOS, set it to default/optimal/recommended settings and test the system. Disable features like BIOS caching.
Use an original and up to date antivirus system like Norton, McAfee or Kaspersky and run a full systems scan.
Keep your windows updated with current patches and fixes to protect the systems from unwanted troubles.
All the best.
Mar 06, 2010 | Microsoft Windows XP Professional for PC
No diplay from monitor and the cpu fan is rotating in d945gcpe motherboard
Pls check the VGA cable & connection.
your RAM may be faulty ,pls check your RAM. If your RAM is good then check SMPS.If SMPS is good then *********** is faulty.
Dec 30, 2009 | Intel Computers & Internet
When i open my pc nothing appears at my monitor. what is my problem of my pc?
first you insure that your PC is powering on. If it is on then it is a hardware problem. may be your PC RAM or motherboard has been faulty.For confirm of RAM you can checked it with another RAM.After checking the RAM your PC do not work then PC motherboard has been faulty.Then you can repaired it from service center.
Oct 20, 2009 | Computers & Internet
I ran diagnostics on my Dell Inspiron 1525. Results: Data Bus stress test failed. Memory compare error, DIMM-B. Suggestion: try to reseat the memory. How should I do? Please help! Thanks T.Doan
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
PM8M3-V
Have you checked with one module at a time to rule out faulty RAM?
May 29, 2008 | MSI PM8M-V Motherboard
eMachines D3415 PC Desktop Logo
51 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
