Question about Electronics - Others
Flash drive problem
When I try to use the flash drive I get a message that says:  Disk in drive F is not formatted.  Do you want to format it now?
But I have had this flash drive for a while now and I have not had this problem before.
Is there any way that I can retrieve that data and files from this flash drive?
  • Anonymous Nov 07, 2008
    absolutly same
  • Anonymous May 07, 2009
    I have data on my sandsk cruzer that i want to save ... it wont let me in and wants me to format it ... if i format i will lose the data so how can i get the data to save it then format?
  • 84 Answers
Sorry to say.. you cant retrieve it...
it happens to flash media .. i dont know what causes this though
Posted on Nov 02, 2007
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computer shows the pen drive without its name. But when I try to open it gives message 'insert disk in drive F'. I started my computer keeping pen drive attached to it, in tis case, the message is ' format...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 01, 2010 | Kingston 4GB Secure Digital High Capacity...
I have an old computer running windows millenium. I used to be able to access my flash drive but now a message pops up that says that i need to format my flash drive. I format the flash drive and try to...
Would you try to format your flash drive using this software which I uploaded HERE. Download and unzip the file. Then run the exe file.
Do the followings:
- First plug in your micro-sd card into you PC using USB cable.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your flash drive).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
- Then restart your computer to recognize your flash drive. Or from control panel, go to Add devices menu and search your flash drive to find and add.
Hope this helps.
May 13, 2010 | 3ware Electronics - Others
2 GB PENDRIVE SHOWING UNABLE TO FORMAT. AND ASLO
You can try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 07, 2010 | Transcend (589307) Media
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 14, 2009 | Kingston Technologies 512MB DataTraveler I...
Can't format flash disk
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 10, 2009 | Electronics - Others
Usb is not responding when inserted into laptop (have tried another computer so fault must be in the flash drive)
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Windows was unable to complete the format 16gb kingston flash drive
windows was unable to complete the format flash drive
Apr 28, 2009 | Computers & Internet
My Transcend pendrive isn't being formatted
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 13, 2009 | Transcend (589307) Media
Usb flash drive problem
2. Format
Nov 11, 2008 | iLO (2 GB) MP3 Player
Electronics - Others Logo
268 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
