Question about Maytag Washing Machines
4A fuse blows when door is opened
Maytag top load washer, upon starting cycle, with door closed, all is ok, when door is opened 4A fuse blows
  • 5 more comments
  • rudi45acp May 11, 2009
    fuse is linked to a switch that is activated/deactivated when door is opened or closed
    Hey guys, I ended up replacing the switch assembly, consisting of fuse, switch and relay.
    I was able to get water into tub, fuse no longer blows, but now washer does not start washing. H E L P
    Maytag washer model #LAT2205AAE
    Rudy
    Got this bad boy up and running, the switch assembly unit comes in this plastic slotted plate, and all I needed was to align it properly so as to engage relay, and presto.
    Appreciate you guys's help.
    RH
  • Samuel Charles Spriggs May 11, 2010
    Hmmmm... Could be just a loose connection, or not. Sounds like another realy is not working. Did you by chance knock any connectors loose while you were working on the machine; or maybe didn't reconnect something you took loose?
    Or, another possibility is there is a short to ground in the lid switch wire going to the relay. This could be caused by a damaged/loose wire running from the switch to the relay.
    The lid switch opens the circuit to the motor when the lid is up preventing the motor from running, and therby preventing the tub from spinning when the lid is up.
    The lid switch probably operates a motor relay. If its fuse is blowing when lid is up, this is probably a normally closed switch -- when lid is raised the switch closes and powers the motor relay. It sounds like the motor relay has a short in its solenoid coil.
    My guess is if you replace that relay the fuse will stop blowing.
    Ther are ways to check this theory, but they're kinda complicaetd. Do you have a voltmeter and experience with repairing appliances?
    A washer pulls more than 4 amps when running normally. Where is this 4 amp fuse?
    President:
  • 1,489 Answers
Great!!
That sounds like a solution to me.
Could you please rate the help -- I think you'll see some icons at the bottom of the screen.
thanks...
Charlie
Posted on May 11, 2009
    Sergeant:
    Champion:
  • 214 Answers
You will need to order a coor kit it comes with fuses all parts including fuses there was a door switch problem and maytag sent a door kit to replace old parts
My Maytag Neptune Washer has an error code "do" What does this mean?
The washer detects that the door is open when
starting a cycle or the door is not locking.
Close the door tightly and restart the cycle.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag MAH5500B FL Washer
Washer Stops
• Plug cord into live electrical outlet.
• Check fuse or reset circuit breaker.
• Close door and push the start/pause pad to start the clothes washer. For your safety,
washer will not tumble or spin unless door is closed.
• This may be a pause or soak period in the cycle. Wait briefly and it may start.
Check screens on inlet hoses at the faucets for obstructions. Clean screens periodically.
If the sreens are colged or even a little sirty it will stop the washer!
Won't fill
• Be sure the door is tightly closed.
• Plug cord into a live electrical outlet. (Tub light should illuminate).
• Press the start/pause pad.!!!!!!!!!!!!!!!!!
• Turn both faucets on fully.
• Straighten inlet hoses.
• Disconnect hoses and clean screens. Hose filter screens may be plugged.
• Open and close the door, then push the start/pause pad.
May be a bad door sensor!!!!!!!
Huuum
Pleae remember to leave a rating
Oct 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag stackable w/d
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
AT702
Jan 27, 2008 | Maytag LSE7806A Top Load Stacked...
Door Lock won't release.
pull your wire in soap dispenser to open door. You may have crimped a wire at door latch assy. when lowering top.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAT12CSDAW
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Jun 20, 2006 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
