Question about Kenmore Dryers
How do u put the belt on? - Kenmore Dryers
My dad has just rec'd the new belt for Zanuusi Tumble Dryer TC 7102W, he has remove the old one and attempted to fit the new, he is far from stupid but the new belt appears to be too big, please advise
Posted on May 11, 2009
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Dec 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Tip
Changing inside pully belt
if you have two belts on your vehicle and need to change the inside one , put the edge of belt one pully that has outside belt and hit key couple times (do not start) the pulley and belt on the outside will turn putting the inside belt on inside without removing outside belt , Will leave small mark on belt that you put on But will not hurt it
on Sep 19, 2010 | Chevrolet Blazer Cars & Trucks
Tip
Putting belt on
when putting belt on use a wire tie/pull tie on the transmission pulley and tie the belt to it put belt on motor and gently pull belt on transmission pulley after it is on cut pull tie and turn pulleys and belt to proper adjustment on tranny and motor
on Dec 08, 2007 | Hotpoint VVSR1070D Top Load Washer
I have a powerclean bissell vaccum and i just got a belt to replace, is pulley the little metal part on the side where belt goes because when i put the belt over the metal part and around rotating brush...
You did not put the belt on its proper place that's why it happen. Replace again the belt and put it not over the metal part. Put a mark where the belt belong so that you'll remember it when you gonna instal the belt. A mark like pen or masking tape will do.
Thanks for asking.
Jul 13, 2011 | Bissell Vacuums
How to put new belt on
remove back, loosen motor bracket, remove belt, put new onw on, belt size on belt, move motor on braket to put tention on belt tighten motor bracket
May 08, 2010 | Whirlpool Dryers
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Deck belt need to no how to put the belt on
How to install a belt for a poulan riding lawn mower deck S#120403A001222 15.5Hp 38" 5sp
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Changing the belt
flip over
remove 3 phillips head screws and remove cover
pull agitator roller out of groove opposite end of drive belt area
install new belt by putting loop around silver drive shaft then putting over belt roller
put roller in appropriate grooves( belt will feel stiff make sure belt stays on roller and under drive shaft put cover back on
You are ready to go!
Jan 03, 2009 | Eureka Luxury Family 8-Person 2-Room Titan...
Dryers Logo
140 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
