Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have a 22 yr old top freezer fridge. I took it to my cabin last year when I bought a new one for the house. However, it does not work-get cold at all. We don't leave the electricity on when we are not at the cabin. Could this be the problem? When we get to the cabin we plug it in. But the 2 days we are in the cabin it will not get cold. Is it worth fixing it, or it too old. We do have another older fridge that the moment we turn the electricity in the cabin we turn the fridge on, it takes about 1 hour and it will get cold. What is the matter with my 22 yr top freezer fridge, Is it worth fixing it? Thanks Cabin fever..
    Scholar:
  • 152 Answers
Ok Sounds like a place i would love to go but .... First, if the trip to the cabin was very bumpy chances are it sprung a leak and lost its gas charge , if this is the case , repairing it may cost more than replacement depending on the location of the leak , if the trip up to the cabin was smooth then consider this, When moving it around to load it up did you maybe move it around suddenly , and if you did this too would cause a leak specially considering  the age of the system, chances are its lost its charge and would require leak testing and repair , here in Australia anywhere up to $ 600.00
Posted on May 11, 2009
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Maytag Bottom Freezer Fridge only a few years old was replaced to sell the house. We just bought our house, moved in and the dishwasher wasn't working so we got a new one. Now our fridge is humming and the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | Microwave Ovens
Does not stay cold. Even with
Sounds like the compressor, or a refrigerant leak. Being a year old I would call Frigidaire and try to get it fixed or replaced under warranty.
Jan 03, 2010 | Frigidaire FRT21H8 Top Freezer...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Ice build-up in the freezer of a Kenmore 19 (Top Freezer) refrigerator, and only 60 degrees in the fridge.
there is supose to be a switch or were the ice is making just figure out which way to turn it off or on. then turn it off and see if the ice stop making. if that doesn't work get a new frige
Jan 29, 2008 | Refrigerators
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
