Question about Dryers
Replaced igniter twice in the last month. is there more to it?
I have replaced the igniter twice in 1 month. is there something i am missing. or am i mis handling it?
    President:
  • 1,136 Answers
Hi, When you changes those ignitors, you can only touch the white part. If you handle the black part, it will not last long at all. Also, make sure the dryer is solid. Some heavy vibration will cause the to break as well. When the ignitor is working, does the dryer dry in proper time?
If it is taking clothes to long to dry, the ignitor cycles to often and that is hard on them too.
I hope this help you. If you have anymore question, please let me know.
Thanks
Vic
Posted on May 11, 2009
1987 toyota camry was running wont start, will not crank, replaced starter twice in the last six months thinking that was the problem
Try moving gear lever from park to neutral then starting, if does not start check starter relay, solenoid or ignition switch, contacts could be worn
Aug 11, 2010 | 1987 Toyota Camry
85 88 royale. Last summer replaced 1 of the valve
She should still have some life left in her. The water pump isn't too hard to replace, really no special tools needed. When motors get around that mileage, they will use some oil and have some leaks. As the engine wears, blow by developes and will cause gaskets to leak. I would also check the PCV valve.
Jun 06, 2010 | 1985 Oldsmobile Delta 88
95 suburban, ignition locks, can't turn key,
Remove the lower steering column cover and check to see if the rod from the ign. lock and tumbler to the ignition switch is binding up. If it's ok, you're problem may be the bearing under the steering wheel being broken.
Mar 29, 2010 | 1995 GMC Suburban
In the last 6 monthes the car has breakdown in front of stop sign, and the battery icon shew on the panel, then I shift to "P" and off ignition, then I start again and shift to "D" and the car running away...
Replace the fuel filter first thing. Remove the battery cables and clean the cable connections and the battery connections. Check all electrical connections under the hood to insure they are tight and secure. Look at all wiring for any wire that may be shorting out as in a bare wire touching metal.
Nov 10, 2009 | 2003 Cadillac Deville
2000 grand am se blower
It could be the actual switch maybe???
May 05, 2017 | 2000 Pontiac Grand Am GT
Shower leaking
Tried new washers with no joy. Replaced hose.
Nov 16, 2008 | Home
Dryers Logo
44 people viewed this question
Top Dryers Experts
