How to make easy shutdown a pc
Tell me how to easy shutdown a pc
  • Ekse May 11, 2010
    press power button
  • 31 Answers
In windows xp or vista you make it easy, using press the power button in the windows environment, it will auto matically shutting down the pc.
regards
Krishan
Posted on May 11, 2009
Acer extensa 4620z whe i shutdown laptop it's shutdown but the screen power still remains on untill i hold the power button to off , please help me
It seems that your computer needs to have a reinstall of your original setup, because the driver that tells it to shut down is not cooperating. Hopefully you have your original dvd/cd.
Nov 20, 2012 | Acer Extensa 4620 Notebook
Tip
Safe and easy shut down for regular Desktop users
Hai from Vishu
For Desktop Systems
when all applications are closed user can depress power button once for a second located on front panel of CPU(not the reset button) to initiate shutdown at one go when system is to be shutdown.( Applicable for all P4 cpu ONLY and not for older system where this action shuts down CPU immediately...)
on Jul 24, 2010 | Computers & Internet
Tip
Create shortcut icon for shutdown and restart on desktop
For easy usage you can now create icon for shutdown and restart on desktop. Right click on desktop in that do to new and then select shortcut. Now you will get create shortcut window will appear. I this you will see one text box for select the location of the item. In that place you need to write "shutdown -s -t 00" without double quotes. and click next. Here you will find the option t rename that icon. after that click on finish.your shortcut is ready on your desktop. This icon for shutdown. If you want to create icon for restart.Follow the same steps above and in the of location of item write "shutdown -r -t 00" without double quotes..
on Dec 23, 2009 | Computers & Internet
My 82 year old mother is having trouble with the multi-gesture touchpad on her acer laptop (aspire 5534) Can you tell me how to turn it off for her?
Im pretty sure you cant turn the mousepad off on the acer shelley.Some OS's let you adjust the sensitivity but the driver is loaded at boot time unless you interrupt the sequence here(which is possible).
Why not try a wi-fi mouse if she doesnt like it,they have a small receiver which fits in a usb port and then a wireless mouse usually optical which is precise and easy to handle.reccommend-- Logitec M305.
god luck
Davey Snake!!
Jul 20, 2011 | Acer Computers & Internet
Turned the TV on..it looked like 3-D (Convergence problem ?) Went to look for the JVC manual (didn't find) Went back in living room...now it's totally BLACK.
pretty easy to diagnose, if a convergence problem it may have triggered shutdown, is power light on front of set now just blinking?
If so I can tell you easy way to prove if convergence problem or not.
This is a fairly easy set to fix that problem in, let me know if you want to know how to confirm this.
Make a comment here and let me know.
SD TECH
Jan 20, 2011 | JVC AV-56WP74 56" Rear Projection...
How do i reboot my acer aspire e500
If in windows, look under the "start" menu for "shutdown". If that doesn't work, most PC's will shutdown if you press and hold the power button for roughly 5 seconds, but doing this can be negative for the equipment if the operating system doesn't respond in time. You might try just pressing the power button one time to see if the O.S. will respond and attempt to shut itself down gracefully. If it doesn't, then just hold the power button in till the machine cuts off. Hopefully, you won't have to make a habit of that. The ideal way to shutdown is to "tell" the O.S. to shutdown, so it doesn't cause a hard drive head crash or file corruption, which while both are remote, are still a potential with a hard loss of power.
Dec 29, 2010 | Acer Aspire E500 PC Desktop
WHEN I SHUTDOWN MY PC THEN IT'S BECAME RESTART AND NOT PROPERLY SHUTDOWN. I HAVE COUR2DUEO PROCESSER INTEL DG31PR MOTHERBARD. PLS TELL ME SOLUTION (DANISH.ALI69@YAHOO.COM)
check out your power options in control panel, this has diffrent options to choose what happens when sertain buttons are pressed.
Feb 09, 2010 | Computers & Internet
Shutdown pc
Make sure you chose "Shutdown" instead of "Restart". Tell me if that solved it. Hope I Helped!
Jan 27, 2009 | IBM ThinkPad T60 Notebook
How did you fix wmp54g Linksys PCI network adapter driver code 10 problem? I googled on this and got tired. Everyone poses this question, but there was no appropriate solution that works around this...
Try this first:
Shutdown PC. Take adapter out. Boot. Install software. Shutdown PC. Put adapter back in. Boot.
If that doesn't work try this:
Shut down the pc before removing or installing adapter.Uninstall device, uninstall software, remove all oem*.inf and oem*.pnf for Linksys products (searched by keyword "Linksys"). Also one of Microsoft drivers was provided for this so I've decided to change its name. After reboot and normal installation procedure everything works ok.
To delete the necessary files go to www.linksys.com/easy and use Netcheck. Easy because this great tool will automatically set-up and install the device for you.
Nov 25, 2008 | Computers & Internet
Suddenly shutdown
Hi.
Try formatting your pc.
Maybe this will help.
Tell me if you still have a problem.
Oct 13, 2008 | Fujitsu AMILO D-7820 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
